Am attempting to set up the SELBEN map. When I get to item 10,[pge4], I find the instructions to type ",value" into the label slot.
Do I delete the 11 "?" marks, then type the ",value", or? [I've tried most every combo and end up w/ a trashed map...] The map is there w/ only the word RPM at the top, the freq values listed, and the map all spread out wide. Looking at the sample, I see that rpm is to be on rows. Mine is backwards.. .
What is "list index out of bounds -1"?? I've just been closing it.
All else seems to be working......
TIA!
