Results 1 to 9 of 9
Thread: Anti Theft Tune
    Sep 2011
    Default Anti Theft Tune
    So I got my DSP5 setup. and Was wondering if this will work and I am looking for other suggestions. Basicly want to disable the truck in position 1 IE stock tune. I went in and zeroed out all the pedal tables and Now can sit with the pedal to the floor and only see 900 rpms. And when I move tunes normal operation...
    Thoughts suggestions?
    Mike
    08 LMM
    Sep 2006
    If you don't want it to start, enter all zeros in the injection pulse and fuel pressure tables...
    2007 CC/SB 4WD, McRat EFI Live, Trans, Trans Cooler and C3 clutch oiling mod by Mike L., SD Sleeves, SoCal Diesel
    2002 CC/DRW 2WD, McRat EFI Live, Trans, Trans Cooler and C3 clutch oiling mod by Mike L., SoCal Diesel
    Sep 2011
    Still want to use remote start so that's a no go.
    Mike
    Dec 2010
    Instead of zeroing out all of the cells (for pulsewidth), zero out the cells for 20-25mm3 and above. That should also help. OR, you could zero out the torque base fuel table, but leave the idle sections. I am trying to think of other ways... Good idea tho!
    Sep 2006
    Quote Originally Posted by jeckeler View Post
    Mike
    Got it...So you park with the switch in the "idle only" position so remote start still works...Unfortunately, the truck could still be idled down the road and loaded on a flatbed or trailer...I zero out in DSP4 so the engine won't fire, but I don't have remote start...
    Jan 2006
    Pardon my curiosity.
    How do you have an anti-theft tune, using a dsp switch that can just be turned in order to drive away?
    Custom Tuning Services
    Sep 2011
    Keylock switch.
    May 2008
    I'm not a diesel guy, so I don't know, but is there different park/in gear fuel/throttle settings you can use, so if they try to take it out of park or push the clutch in it will die?
    E85 is NOT flex fuel.
    2003 Chevy S10 4.3L LU3 LS1B Auto
    48 LB injectors
    Race Proven Motors 2114 intake
    T70 turbo.
    Jan 2006
    Keylock switch.
    Go with The Neens recommendation then.
    BTW, there is a way to build an anti-start tune, that will prevent startup, but not kill the engine once it has been started in another key position. But this is not what you are after apparently. It is however a safer way to tune, for someone who is going to be switching on the fly. Idle only is very effective for theft protection IMO. Maybe moreso, as it will likely result in a panic bailout, instead of further interior damage.
  1. E37 anti theft disable
    By MisterBill in forum E37, E38 & E67 PFI ECM's
    Last Post: August 1st, 2011, 05:47 AM
  2. VE SS commodore Anti theft
    By limited cv8r in forum General
    Last Post: May 23rd, 2010, 02:34 PM
  3. Anti-Theft???'s
    By GAMEOVER in forum Gen III V8 Specific
    Last Post: November 9th, 2009, 06:17 PM
  4. torque,anti abuse?
    By 2004gmc in forum Lounge
    Last Post: May 28th, 2009, 01:52 PM
  5. Theft disable
    By VHR in forum General (Diesel)
    Last Post: July 7th, 2008, 10:35 AM
