Hey guys,
Here's the lowdown, 2006 LBZ, got super sluggish on the bottom end of first gear..... from what I can see in the log every parameter is hitting the mark, pulse width, timing, boost, FRP, Torque based fuel, MAF, all dead on.....
However, it's taking forever to build torque, when I watch the log on table B1115, the cell goes straight to the bottom like it should but the actual readings are much slower to follow.
Hopefully someone else has had this problem, I'll post the tune with it but please note the following, The top end fuel pressure in the tune I'm posting has been increased, and the top end pulse width has been decreased some. The problem area has not been changed.
Truck has a 6" lift, 35" tires, 80hp injectors, lift pump @10psi, and Fleece 64mm Cheetah in stock housing.
