Results 1 to 5 of 5
Thread: Twin Turbo AES 390 in 70 AMC Javelin
    Mar 2011
    Default Twin Turbo AES 390 in 70 AMC Javelin
    I just got my car running on a simple tune, i dont have any of the 02 sensors or wide band hooked up yet, i just want some opinions on what you think. so i have the option to pay some one a fair sum of money to help me tune, or use the fourms and tutorials and save my money.
    im feeling confident now that i got the car to run, idle and rev fairly well.
    i have efi live f/s v2, stream licence ect.
    COS 3, S/D no maf, turbo 400,
    i know i cant tune untill i get the down pipes built and 02 sensors in place. im having problems understanding PID's Maps, setting up a proper dash, customer details, display units. stuff like that.
    take a look and let the information flow. if your in my area your welcome to use my stream license's in exchange for helping me with my tune. or im a hell of a welder/mechanic.
    1970 AMC Javelin. AES 390ci. MAST CNC LS3 heads,DragonSlayer-Ultra rods, Vic.Jr., wilson, N-W 102 T/B, 95lb. "FIC 1000cc. injectors", Lonnies Performance twin pumps/harness. Twin TC-70-65's flipped manifolds, A/W intercooler, TH-400, Griner 1+2 trans brake, PTC converter, 3.50 gear 29-18.5-15 tires. Alston Battle Cruizer 4-Link, Fab-9. Cage, tubs, PSI harness, 0411 ECM. EFI Live,
    Mar 2011
    i built my down pipes over the weekend, i used Borla stinger mufflers, wow does it sound mean! had to order some o2 extentions for the N/B sensors. the wide band works great. having my drive shaft built this week as well. Stay tuned!
    Mar 2011
    Hey mad, the timing seems real low at idle, are you running a distributer? Lots of efilive guru's on here so hopefully someone can help you out. Glad you have it running!
    Mar 2011
    no distributor, i dont understand why we have a main spark table then two idle tables, my P/N wire is grounded, im guessing that tells the computer it is always in gear, so do i change the timing in just the "timing in gear table?" i used the controls to fix the timing to 33 at idle, that is where it is happy.
    Mar 2011
    Default here you go.
  1. Twin Turbo CTS-V help
    By gotabav in forum Gen III V8 Specific
    Last Post: July 24th, 2011, 10:29 PM
  2. Need a Twin Turbo Tune
    By mackattack in forum Duramax LB7
    Last Post: April 20th, 2011, 01:30 AM
  3. twin turbo's
    By limited cv8r in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: July 15th, 2007, 03:22 AM
  4. STS Twin Turbo
    By purrvert in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: December 20th, 2006, 09:25 AM
  5. 02 Vette Twin Turbo
    By lplott in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: August 25th, 2006, 04:17 AM
