Results 1 to 8 of 8
Thread: Unique 09 e67 os ecm
    May 2009
    Default Unique 09 e67 os ecm
    [ATTACH]Tune 11919[/ATTACH]
    It is from an '09 Saab 9-7X AERO. For some reason this OS just does not like to take the usual tuning tweaks that previous '07-08 TBSS's like. No matter what, when you go WOT from idle it triggers an ECM Internal Failure and goes into limp mode. Can you more experienced guys see anything, possibly an unlocked spark or fuel parameter, that may be causing it?
    Trailblazer "RS" 5.3L 6L80 4x4 & '07 TBSS LS2 6L90 AWD
    Feb 2006
    Is this the stock file, could it have been modified before you read it?
    Al
    May 2009
    No it's stock out of a stock truck
    Dec 2007
    Quote Originally Posted by TBMSport View Post
    Is this giving you trouble in a Saab or with the LS2 in your TBSS? And is the tune you posted the one read out of one of these vehicles or is it from the EFILive tune file tune depot?
    May 2009
    It runs fine in the Saab. The thing is when you put a TBSS in a Saab the aforementioned drive condition occurs. Conversely, when you put this Saab cal in a TBSS, same condition occurs. Having spent several months adjusting PE, spark, knock, misfire, and fuel (which does change and improve driveability) is leading me to think that there are some extra tables for '09 E67's that are not being given to us.
    Dec 2007
    You swapping ECM's or just calibrations? And are the throttle bodies the same? And what extra tables would be missing?
    May 2009
    Not sure...I'm thinking for '09 they may have gone with a different TB...maybe that infamous 'gold' blade. Maybe that's the problem.
    Dec 2007
    Nothing wrong with the gold blade Just needs the right ETC cal.
    Were you swapping tunes or whole ECM's? i.e. SAAB tune into TBSS ECM?
  1. Not connection to E67 ECM
    By khalidmmukhtar in forum E37, E38 & E67 PFI ECM's
    Last Post: March 9th, 2010, 08:40 AM
  2. I have a unique and irritating problem with my 402 '01 Firehawk
    By the Dragon in forum Gen IV V8 Specific
    Last Post: July 16th, 2009, 07:13 AM
  3. what tune can i use for a 6.2L VVT W/E67 ECM
    By nycblazer in forum E37, E38 & E67 PFI ECM's
    Last Post: January 16th, 2009, 01:03 PM
  4. New part number for E67 ecm?
    By XLR8NSS in forum E37, E38 & E67 PFI ECM's
    Last Post: June 7th, 2007, 01:21 PM
  5. Reading an E38 / E67 ECM
    By GMPX in forum E37, E38 & E67 PFI ECM's
    Last Post: June 6th, 2007, 07:02 PM
