Results 1 to 10 of 16
Thread: B3601?
    Jan 2008
    Default B3601?
    I'm trying to get my truck tuned for 10% ethanol, I've read in multiple post where it ways to change B3601 to 14.12. My B3601 in a chart (photo attached) not just a single cell like I've noticed on the tunes people have posted. Do I need to change all those to 14.12? I'm assuming this is for a flex fuel vehicle, my tune file has the flex fueloption, which is off, but my truck is not a flex fuel. Thanks for the help.
    2006 GMC CCSB 1500HD 4X4 - Radix 3.2 pulley, Pacesetter Long Tubes, Magnaflow exhaust
    Yes, correct, the single-celled B3601 is for single-fuel vehicles.
    Your ECM already takes care of alcohol composition, so leave your multi-celled B3601 as is.
    Jan 2008
    Joe,
    Since the truck is not a flex fuel will the table still work? I only ask cause I've never noticed my commanded AFR change from 14.68 at cruising speeds even though I know there is ethanol in my fuel.
    May 2008
    You can try to change the default ethanol percentage if you don't want to make the table flat.
    2003 Chevy S10 4.3L LU3 LS1B Auto
    48 LB injectors
    Race Proven Motors 2114 intake
    T70 turbo.
    Jan 2008
    I'm just looking for the correct way to get my tune right. I changed all the cells to 14.12 before I had gotten any replies on this thread. It now commands 14.12, but if that's not the correct way to do it then I'll change everything back to the way it was.
    Lifetime Member Chalky's Avatar
    Sep 2003
    I can't see how changing any cell other than 0% will make any difference in a non flex fuel vehicle. In all likelyhood, a flex fuel vehicle will have the same tables as your non flex vehicle but with flex fuel option activated. That is when the other cells would be used depending on ethanol content.
    I changed a couple of different cars to 14.35 in the 0% cell only to recognize 5% ethanol that we have in our area. It works fine. Of course, both cars were dialed in as far as VE and MAF goes prior to changing to 14.35.
    2015 Z06 A8
    Jan 2008
    Is changing the B3601 to match the ethanol content helping with fuel mileage any? I know the change is making it richer so I would think not. My truck has dropped about 1.5mpg since the 10% ethanol hit the pumps.
    Sep 2003
    Changing B3601 will cause you to consume more fuel. You might be better off leaving B3601 @ 14.63 and just set PE around 12.3. Confirm with a wide band.
    12.3:1 AFr is about ideal for 5% ethanol for max safe power. 10% ethanol would require a 12.1:1 AFR PE.
    I bought a test kit to confirm ethanol content in my area. I am seeing 5% ethanol in the summer. Not sure what it will look like in the winter.
    B3601 seems capable of handling E10 fuel even using factory B3601 settings of 14.63. Only problem is as more ethanol is added to fuel, cruise conditions dictated by 14.63 will cause a leaner mixture. At some point as more ethanol is added to our fuel B3601 will most likely have to be enriched.
    2015 Z06 A8
    Dec 2010
    Quote Originally Posted by Chalky View Post
    The ECM will compensate for the added ethanol by using the fuel trims. Therefore, E10 and pure 87 gas will run stoich in our motors, no matter what mixture between 87 and E10 the pumps have. By changing the desired AFR for E10 and you run E10 all the time, you will see your fuel trims fall back into place, instead of adding fuel. The best would be to split the distance between 87 and E10 for your desired AFR so you can fill up and your trims will be very close no matter which fuel mixture you put in your tank. Now if you put E85 in, thats a different story
    If your vehicle has that multi-celled B3601 table, how does it determine the ethanol content % so it can lookup B3601...?
  1. B3601 value for E10
    Last Post: August 28th, 2015, 12:09 AM
  2. B3601
    By curtbriggs in forum General (Petrol, Gas, Ethanol)
    Last Post: December 5th, 2010, 03:43 PM
  3. B3601 and returning to CL
    By Gregs in forum Gen III V8 Specific
    Last Post: May 1st, 2010, 12:48 AM
  4. Logworks and {B3601}
    By mr.prick in forum General (Petrol, Gas, Ethanol)
    Last Post: June 28th, 2009, 06:24 PM
  5. B3601
    By johnv in forum General (Petrol, Gas, Ethanol)
    Last Post: November 23rd, 2005, 11:24 AM
