Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: B3601?
    Lifetime Member Chalky's Avatar
    Sep 2003
    If your vehicle has that multi-celled B3601 table, how does it determine the ethanol content % so it can lookup B3601...?
    From what I understand, the flex fuel vehicles have a sensor in the tank that measures ethanol content. Based on Ethanol content, it will select the appropriate cell in the table in B3601 as stoich for the blend in the fuel tank. With every fuel up, the blend is evaluated again for ethanol content.
    2015 Z06 A8
    Dec 2010
    Quote Originally Posted by Chalky View Post
    Changing B3601 will cause you to consume more fuel. You might be better off leaving B3601 @ 14.63 and just set PE around 12.3.
    B3601 seems capable of handling E10 fuel even using factory B3601 settings of 14.63. Only problem is as more ethanol is added to fuel, cruise conditions dictated by 14.63 will cause a leaner mixture. At some point as more ethanol is added to our fuel B3601 will most likely have to be enriched.
    The ECM will compensate for the added ethanol by using the fuel trims. Therefore, E10 and pure 87 gas will run stoich in our motors, no matter what mixture between 87 and E10 the pumps have. By changing the desired AFR for E10 and you run E10 all the time, you will see your fuel trims fall back into place, instead of adding fuel. The best would be to split the distance between 87 and E10 for your desired AFR so you can fill up and your trims will be very close no matter which fuel mixture you put in your tank. Now if you put E85 in, thats a different story
    May 2008
    I was figuring you could enable it and set b3103. The sensor isn't actually in the tank, it goes on the fuel line. I got one for mine, but it was bad, so never set it up.
    2003 Chevy S10 4.3L LU3 LS1B Auto
    48 LB injectors
    Race Proven Motors 2114 intake
    T70 turbo.
    Jan 2008
    Where does the sensor go on the fuel line? Would the factory harness already have a plug for it? Just curious, if it was plug and play it seems like the best way to go. Also I've attached a pic of the flex fuel tab in my tune file to help explain what I'm looking at.Click image for larger version.
    2006 GMC CCSB 1500HD 4X4 - Radix 3.2 pulley, Pacesetter Long Tubes, Magnaflow exhaust
    May 2008
    It isn't plug and play since they were on the 2.2L s10, there is no wires run to the PCM. I have -8 fuel line run to my engine, but it looks like they use the GM quick disconnect fittings. The sensors are stupid expensive, which is why I didn't get another one.
    They looked like this:
    http://cgi.ebay.com/ebaymotors/Flex-...item230b8e7b92
    There's a used one here too:
    http://cgi.ebay.com/ebaymotors/GMC-F...item19c8d55b15
    48 LB injectors
    T70 turbo.
    Jan 2008
    Thanks for the info, that's out of my price range at the moment.
  1. B3601 value for E10
    Last Post: August 28th, 2015, 12:09 AM
  2. B3601
    By curtbriggs in forum General (Petrol, Gas, Ethanol)
    Last Post: December 5th, 2010, 03:43 PM
  3. B3601 and returning to CL
    By Gregs in forum Gen III V8 Specific
    Last Post: May 1st, 2010, 12:48 AM
  4. Logworks and {B3601}
    By mr.prick in forum General (Petrol, Gas, Ethanol)
    Last Post: June 28th, 2009, 06:24 PM
  5. B3601
    By johnv in forum General (Petrol, Gas, Ethanol)
    Last Post: November 23rd, 2005, 11:24 AM
