JdegraphCT_2.1[1]_help.tun
B4703 in gear airflow needs to be higher than in neutral to take the load of the trans. Do the RAFIG process to set this up correctly this will make idle transitions spot on. Add 2g/s to the whole in gear table reflash and start from there.
Your throttle cracker table looks way to high. This will cause the car to feel like it surges foward when you are off the gas. Log where this happens at what speed and rpm and adjust this table downwards until you get a nice slow decel when off the gas. Make broad changes at first like 1g/s until you feel a change then fine adjust in 0.2g/s increments. I have included a good cracker table in the tune below that will put you in the right direction. They take a while to set up on the road but are worth getting right....
Timing also affects this decel feel so look at your spark table and maybe decrease spark in the decel area. Remember that max timing anywhere can only be less than 40deg so change all your 50's & high 40's in your spark high & low maps down to 40 then adjust downwards from there according to the feel when decelerating> aim for 25 to 30 deg in the decel areas.
