Results 1 to 10 of 13
Thread: trans tuning for the allison
    Jan 2006
    Default trans tuning for the allison
    i hope you guys dont give up with the allison tuning, us guys would really benefit from it. the ford guys are really benefitting from trans tuning from the sct programmers that are out.
    02 2500hd ccsb d/a, edge/attitude, banks 4", k&n genII intake, 305/70/16E nittos, ppe boostvalve(32+psi), oru leveling kit,bullydog shift improver(completely useless, still limps tranny)
    01 2500hd std cab lb d/a, 4"diamondeye, k&n flat panel diablosport predator, 8'2" boss v plow, airflow stainless v-box salter
    05 honda trx 450R quad, completely stock, except for nerfbars, handlebars, grabbar, front race bumper
    We haven't given up!!.
    We have something else in the works for the Duramax that is taking up all our R&D time
    Jan 2006
    we need the tranny tuning to hold more power
    Lifetime Member Max Power's Avatar
    Nov 2005
    The tranny tuning on the Duramax will not allow it to hold much if any more power. It will be used to improve shifts etc.
    This will not replace tranny mods that we are doing now. Sorry.
    09 LMM Duramax
    EFILive Distributor Trippin's Avatar
    May 2004
    I doubt tranny tuning alone will enable you to hold more power without going in and changing some hard parts. Get with ATS or Suncoast and get yourself some good stuff. Then the tuning will allow you to adjust TCC lockup and shift points.
    www.socaldiesel.com
    EFILive-DSP5......Switch your Attitude!
    EFILive-CSP5......The Smart Way To Switch Your Cummins Tunes!
    EFILive-DSP4......Switch Your Colorado and Canyon Too!
    Jan 2006
    my trans limps at the weirdest times, i am going to get the suncoast converter and trans, but what about shift points? i want to run 315s on my truck without regearing it?
    May 2004
    Using EFILive to correct your speedo readings and a Tech 2 to correct the ABS readings should help get the shift points back to stock.
    As for the limp.........................either Viagra or Suncoast.
    Of course a performance built Allison trans and Triple converter has been known to induce the same result as Viagra.
    www.socaldiesel.com
    Quote Originally Posted by Dmaxvaz
    We haven't given up, the Allison TCM just does things very different to any other Delco/Delphi supplied computer, it sure makes you say - more often than not.
    Dec 2005
    Quote Originally Posted by GMPX
    Is it looking like it is doable?
    Well we have signs of it being doable, but right now, getting DSPĀ² out of Beta is the main R&D priority.
  1. Need trans tuning help
    By Gregs in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: April 1st, 2010, 04:09 PM
  2. 8.1/allison tuning
    By smokin6.5l in forum Gen III V8 Specific
    Last Post: February 6th, 2010, 11:34 PM
  3. Need help with trans tuning..
    By BowlingSS in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: January 24th, 2010, 01:58 PM
  4. Tuning a trans
    By sheamus in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: December 17th, 2008, 06:16 AM
  5. E38 Trans Tuning
    By ARK 99coupe in forum E37, E38 & E67 PFI ECM's
    Last Post: June 15th, 2007, 03:38 AM
