Results 1 to 5 of 5
Thread: E40 stops spitting data over 5500rpms at WOT
    Jul 2003
    Default E40 stops spitting data over 5500rpms at WOT
    Hello Paul,
    I had to change the scanning method from Dynamic to Stream Fast in order to get data spit over 5500rpms. The bad thing is that i only get 6-7fps.
    Chris
    I don't know if others have seen that, but the E40 uses the old 68000 based CPU, not the E38's PowerPC, maybe it's struggling to keep up?
    Jul 2003
    Could be... i loaded less parameters and changed from stream-fast to dynamic...
    I need to do some more logging with less parameters in stream fast.
    I would have thought they were a better ECU than the ls1.
    Quote Originally Posted by Highlander View Post
    Nope, it's kind of the same actually.
    Jul 2003
    Well, they both use a 24x reluctor...but still...
  1. Throttle stops working when accelerating..
    By iViLe in forum Gen IV V8 Specific
    Last Post: May 19th, 2011, 09:48 AM
  2. Freeze Frame Data not available for E40?
    By DrkPhx in forum General
    Last Post: October 27th, 2010, 02:05 PM
  3. E40 Tow/Haul mode input wire at E40?
    By ssvolvo in forum Gen IV V8 Specific
    Last Post: March 23rd, 2008, 10:55 PM
