If I increase the MAF over 400g/s it will fall off on power big time, 50- 100rwhp. If I keep MAF @ 399g/s or under it pulls fine on the dyno.
Any Hz I command the 400 g/s at or higher is when it will fall off at wherever RPM it meets. I've had it hit at 3600rpm and up to 5300 rpm, but it runs too lean at the higher rpms. I limited it @ 399 and made huge increase in commanded pe and the mixture is good just not pulling the same power as I would like due to this. Any suggestions or similar situations I can be directed to?
Thanks,
Jason
