Results 1 to 10 of 11
Thread: Quick question
    Member 2007chevy5.3l's Avatar
    Aug 2011
    Default Quick question
    Hey guys,
    Im gonna try my hand at doing some tuning on my Tahoe with fuel trims and have a question. I set up everything accordingly to what swingtan said in this post http://forum.efilive.com/showthread....l=1#post140595 But i do not know how to create a custom PID to convert the +/- percentage into a BEN since the STFT's are in a "%" reading. Can someone help me out on this?
    Thanks,
    Justin
    2007 5.3l Tahoe. K&N CAI, Pacesetter LT/ORY no muffler, vette servo, Tru-cool 40k, Innovate LC-1 wideband, 3.42's Circle D 3k, 100shot
    Slowly learning how to tune via EFILIVE
    Aug 2010
    Hello Justin,
    Attached is an example of fuel trim calc_pids - BEN from LTFT and STFT.
    Regards,
    Taz
    Aug 2011
    Thank you Taz
    So now I just plug that in to the calc pid note pad and save it? Not really sure how it all works....
    Aug 2010
    Hello Justin,
    It might be easier if you posted your current calc_pids.txt file. But make a back up copy first.
    Go to C:\EFILive\V7.5\User Configuration … you should see your calc_pids.txt file in this directory.
    Open this file with Notepad. Then use the “Save as” command – to save an unaltered copy … call it something like calc_pids-original.txt.
    Then post a copy of this file … I’ll add in the fuel trim CALC PIDs for you.
    Regards,
    Taz
    Aug 2011
    Hey Taz,
    Heres the Calc Pids. Let me know how you do it so I will know if I ever have to do it again
    Thanks a ton!
    Justin
    calc_pids.txt
    Aug 2010
    Hello Justin,
    My apologies for the delay in response ... the appearance of cooler weather here has everyone scurrying to get their projects completed before the snow arrives ... in 6 weeks or so.
    In your signature you list "LC-1 Wideband" ... so I assumed this was a Serial WBO for the purpose of the calc_pids ... have never used an LC-1.
    In the calc_pids this WBO is represented by the "EXT.WO2LAM1" expression ... you may need to alter this, if I have selected this incorrectly for your setup or this WBO.
    Save this file as "calc_pids.txt" in the User Configuration folder ... and it will replace your currently empty file.
    Regards,
    Taz
    Aug 2011
    Taz,
    Yes my LC1 is a serial wideband. I see that you set the calc_pids to EXT.WO2LAM1, I believe this will read in Lambda. I am not very familliar with Lambda since we all use AFR... Will I need to change it to say WO2AFR1??
    Thanks!!
    Justin
    Jul 2007
    In all honesty, I wouldn't use a BEN if correcting using the STFT's. I've tried it and gone away from it.
    We know that the two banks do not run the same fuel trims and the ECM manages the trims separately. So averaging them together does what the ECM is trying not to do... I chose one bank to work from and generally don't worry about the other unless I'm sanity checking. Remember that tuning is not a substitute for components in good mechanical condition, I'm going to assume that the rest of the engine is working correctly and that the NB O2's are good.
    I'd then just log data while driving, ensuring I had the STFT's and other related PID's selected. Once a logging session was complete, I'd review the data and choose specific sections (by looking at where the STFT's were significantly out) and making adjustments to the MAF or VVE based on the sections I chose from the log data. working like this allows you to easily ignore transient area's or areas where you know data may be bad ( hot starts etc ).
    Simon
    Quote Originally Posted by 2007chevy5.3l View Post
    Taz,
    Thanks!!
    Justin
    Use lambda, otherwise AFR will be incorrect unless you used fuel with a stoichiometric ratio of 14.7.
    Lambda is independent of the fuel's stoichiometric ratio.
    e.g. in each of these cases, when the wideband read stoich it will report lambda as 1.00:
    - E00 = stoich 14.7
    - E10 = stoich 14.2
    - E85 = stoich 9.7
    lambda = AFR / stoichAFR
    or
    AFR = lambda * stoichAFR
    Aug 2011
    Quote Originally Posted by swingtan View Post
    Simon
    So what your saying is just log the data and where ever the trims are out then adjust the MAF frequency conversion to get it right??
  1. Quick TC question
    By InTruckDesign in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: November 4th, 2010, 10:54 AM
  2. Quick Question
    By duramax07tmd in forum General (Diesel)
    Last Post: March 16th, 2010, 03:06 PM
  3. quick question
    By justin123 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: April 17th, 2009, 10:55 AM
  4. quick question! please help
    By nonnieselman in forum General (Petrol, Gas, Ethanol)
    Last Post: November 24th, 2008, 08:41 AM
  5. Quick OS question
    By ViolatorTA in forum General (Petrol, Gas, Ethanol)
    Last Post: February 12th, 2006, 12:45 PM
