I have been trying to use these tables:
{B0917} Injection Timing IAT
{B0918} Injection Timing IAT Multiplier
but they aren't having any effect. Tune is a DSP2 based on federal LB7 OS 15189044.
ID:	11990Click image for larger version.
I have a thread over on DuramaxDiesels (http://www.duramaxdiesels.com/forum/...ad.php?t=34271), and it was suggested I post here, since it is probably an issue that requires EFILive intervention.
Killerbee said the LLY had the same problem, and Ross made a fix to get the tables working. Does something similar need done here?
If it makes any difference, I only did a calibration flash when loading the new tune. I thought the only time a full flash was needed was with the DSP2 & DSP5 tables.
Any ideas are appreciated. Thanks,
David
