Hi
I am installing an E-Force supercharger on my LS3 engine. The engine is running
on COS 5 (156). I wonder if I can use the IAT signal from the TMAP sensor that is in the supercharger housing.
Does the IAT signal need to be scaled in the tun? And is it possible to adjust the settings on this os?
I have scaled the MAP sensor: Linear 223.43 kPa and Offset -7.88 kPa.
But I am not sure what to do with the IAT. I feel that the best thing would be to use the tmap sensor because it is placed after the intercooler in the manifold.
I can use the IAT sensor in the MAF but what is the best solution?
Tor
