Results 1 to 3 of 3
Thread: E37 unpredictable spark timing and lean cruise
    Jul 2011
    Default E37 unpredictable spark timing and lean cruise
    I'm sure this is simply due to my inexperience, hoping y'all can ...
    Vehicle is a 2007 Cobalt running on 100% Methanol.
    The setup we have here is a Dynocom Dyno, with our own internally developed software (using a Labjack for data acquisition) that controls the dyno with a PID control loop to hold the car at a specific RPM by providing a signal to the dyno's Eddy brake. I hold the throttle at a specific air flow (by monitoring the grams/cyl PID on the computer screen). We then sample the load cell output and use that to calculate power and efficiency, record that and manipulate timing to achieve maximum efficiency, and thus best mileage which is the goal of this project. The problem I am having is that I cannot seem to predictably manipulate spark advance using EFILive...the advance numbers being reported just do not correlate with the parameter file. For example I can add 4 degrees of advance at a specific RPM from .08 to .20 grams/cyl of air flow (three cells). When I run the car I will see something like the .08 air flow cell having 6 degrees more than the parameter file, and the .20 cell having 6 degrees less than the parameter file (this is very consistent, and I am not able to find a spark parameter that is causing this), and often the reported advance numbers just do not change after adding (or subtracting) timing from the parameter file (I tend to go in about 2-4 degree increments). I have (only for the sake of testing) zeroed out all of the various spark advance multipliers, so as not to effect final advance, and set the max torque reduction via spark to zero...this has had no effect.
    Again I'm sure there is something simple and stupid that I'm missing, I just don't know what the heck it is!
    Oh and also wanted to ask if this ECM supports lean cruise?
    Thanks in "advance" (pun totally intended )
    Bill
    EDIT: probably worth mentioning that high octane and low octane spark tables are kept identical to each other
    Jul 2003
    Verify the fuel mixture spark table.
    Jul 2011
    The discrepancy was being caused by using the PID called "Air Mass" as opposed to "Air Flow". Both are in grams/cyl, and I have no idea what the difference is, but the "Air Mass" PID is off by about a factor of 4.
  1. Lean Cruise help
    By Manbearpig in forum Gen III V8 Specific
    Last Post: March 7th, 2010, 02:38 PM
  2. can a lean idle or going lean during light cruise harm the engine?
    By ryans1000 in forum General (Petrol, Gas, Ethanol)
    Last Post: November 3rd, 2009, 01:44 PM
  3. RR Lean cruise?
    By BRD-PREY in forum RoadRunner Real-Time PCM Emulator
    Last Post: January 11th, 2009, 06:31 PM
  4. Lean Cruise and Cruise Control
    By neil in forum Tuning For Economy
    Last Post: July 9th, 2007, 09:42 PM
  5. lean cruise
    By 69camaro5speed in forum General (Petrol, Gas, Ethanol)
    Last Post: January 14th, 2006, 10:43 PM
