Results 1 to 4 of 4
Thread: Lean idle?
    Oct 2005
    Default Lean idle?
    Ok, what am i missing? Doing the VE Auto Tune thing and it's everything the motor can do to idle (WAY lean) on initial startup. It doesn't matter if it's hot or cold. For the first few seconds, about 10 or so, it runs way lean then almost appears to go into closed loop, but that isn't possible right now with the Auto VE settings. After those first few seconds, it idles fine. All settings are per Auto VE instructions.
    408,TH-400 manual shift, two stage NOS, 4.10\'s, blah blah blah
    Jan 2004
    Its not you at all or anything you are doing wrong. Check out this link.
    http://efiforum.iqd.co.nz/showthread.php?t=1683
    Oct 2005
    Muchos grassyass. I don't feel so bad now at least. I have to agree with you that i think there is a table in the PCM that we can't see/modify.
    Jan 2004
    Not sure if you fixed your problem already or if you have your AIR pump installed, but disabling my air pump fixed my actual wideband readings on cold start.
  1. WB showing way lean @ idle
    By Afterhours Performance in forum Gen III V8 Specific
    Last Post: November 29th, 2009, 05:39 AM
  2. can a lean idle or going lean during light cruise harm the engine?
    By ryans1000 in forum General (Petrol, Gas, Ethanol)
    Last Post: November 3rd, 2009, 01:44 PM
  3. Running Lean at Idle
    By mikeyayell in forum Gen III V8 Specific
    Last Post: December 28th, 2007, 07:55 AM
  4. LS2 402 lean idle
    By white2000ta in forum General (Petrol, Gas, Ethanol)
    Last Post: April 3rd, 2006, 04:59 AM
  5. Very lean at idle RPM/MAP problem
    By jnorris in forum General (Petrol, Gas, Ethanol)
    Last Post: February 17th, 2006, 10:29 AM
