Basically the car ran well enough to get me to class and back Tuesday. Wed. morning I flash the pcm with some changes. I start the car, it ran, but not very well. Needing to go to the store I flashed the tune back in I was using the day prior. Go to start the car, cranks for about two seconds then nothing. I try to crank again, nothing. Get the starter and battery checked out, both check good. Someone suggests I'm hydrolocked on fuel. Yep, pull plugs and rotate motor by hand, gas is coming out of all the cylinders.
Any ideas on why the car is doing this? It started after the second reflash. Both flashes went fine and normal, no errors.
For some reason though the motor will fill up with fuel before it ever has a chance to light off. It is happening really quick and I have no idea why.
I'm almost tempted to throw an optispark back in the car.
