Results 1 to 1 of 1
Thread: ETC issues
    Jun 2009
    Default ETC issues
    I'm having two separate issues here and would appreciate any ideas.
    The vehicle is a 2001 GMC Sierra C3 which uses a electronic throttle very similar to the ones the C5 corvette used. However, the stock 78mm TB has been swapped out to a ported and polished 90mm LS2 TB on a TBSS intake.
    Anyways, issue: on the 2-3 shift, the shift is being delayed because the throttle is closing to 40%. It will delay and then pop back up to around 100% and shift. This delayed shift always seems to occur after the first 2-3 WOT shift which occurs properly. I have all of the torque management out (trans is built) and all the abuse parameters are disabled, as far as I know. I bet I'm missing something somewhere, I just can't find it. Also want to add that the 1-2 shift @ 5900 rpm is always fine, it's just the 2-3 @ 5800.
    Andy truck - Copy.tun
  1. A/C issues
    By Naf in forum Gen III V8 Specific
    Last Post: June 15th, 2009, 12:07 AM
  2. KR and VE issues
    By Beer99C5 in forum Gen III V8 Specific
    Last Post: May 27th, 2008, 08:52 AM
  3. Known issues in V7.1.16
    By Blacky in forum General (Petrol, Gas, Ethanol)
    Last Post: January 24th, 2005, 05:21 PM
