Results 1 to 10 of 11
Thread: 2010 VE Commodore with T43 and big(ish) HorsePower??
    Jun 2011
    Default 2010 VE Commodore with T43 and big(ish) HorsePower??
    Hey guys,
    Fairly new to the forum on here...plenty of reading to make my head hurt though!
    I have a question....
    Anyone out there with a fairly new T43 transmission (I believe my OS is 24256125) that is running big horsepower?
    I'm putting out about 500-550rwhp through a bog stock T43. The tune has of course been played with to accommodate this increase in power, as well as a 2800 TCE convertor.
    I don't have many, or any, issues when driving around town at part throttle.
    The problems are at WOT when I'm running at the drag strip.
    The box struggles to shift from 1st to 2nd and then 2nd to 3rd. Once it finds 3rd it pulls strong and hard and shifts into 4th with no problems and holds all the way to the line.
    I've attached the tune as well as some runs from the track...
    Any thoughts? Comments? Questions? Appreciate the feedback and help...
    T43 Tune 24092011.ctdCalder 17092011 1st Run.efiCalder 17092011 2nd Run.efi
    Since those runs, I believe I have set up the Torque Convertor so that it doesn't lock up at all under WOT.
    Mar 2011
    Coincidentally I have a very similar problem only at wot the car seems to hunt for the first 2 gear changes and it seems like its getting confused and can't select the gear or the engine bumps the limiter and at times I think this does happen for me. I am having trouble with BBL can't seem to log the data I require to help determine the fault.
    What is your limiter set to in your ecm tune?
    If you find a solution please share
    Dec 2007
    Quote Originally Posted by HEKYEH View Post
    Your log shows 600Nm at 6500rpm which is around 550 crank HP, so if you are doing 550 at the rear wheels there is a torque mismatch.
    Are you FI with 4-5 lb of boost? The MAP shows at around 130kpa.
    Timing is being pulled for the shift but torque is not dropping so it is reducing throttle as well. Be worthwhile logging clutch pressures too.
    This motor has some serious herbs.
    Jun 2011
    Quote Originally Posted by gmh308 View Post
    Yeah, forgot to mention...Here are the engine mods:
    L77 engine, 6 litre
    222/227 @ 115 cam
    Harrop HTV1900 blower (Believe it's running at about 7-8psi, but there is belt slip...and spiking)
    Valve springs, Morel link bar lifters, pushrods....all those good bits!
    OTR CAI
    What are the PIDs for clutch pressure? I think I might have added them since doing those runs...
    E38_0016.efi
    Jun 2011
    Any thoughts out there on this??
    Mar 2011
    My e38 tune could be causing my issues as my
    Max spark retard and
    Power reduction timing were not set right
    I am yet to confirm that this is the cause.
    maybe if you post your e38 tune someone may look over it to see if you have any issues?
    I did notice you are hitting the limiter 6500rpm like my car was and there is no torque reduction before the shift also like mine
    Jun 2011
    Here you go...
    E38 Tune 13092011.ctd
    Mar 2011
    Here you go...
    My issues are deeper than yours but some things to note in your run1 at calder
    Your 1-2 change is happening too late and your hitting limiter you are set at 50kph wot
    Try adjusting wot rpm and wot shift speeds down until it stops hitting limiter it needs both to qualify for a shift.
    it seems that at frame 396 your rpm is flaring quickly not sure but maybe slipping trans?
    Jun 2011
    OK, so what you are saying is that for a gear to change successfully, it both needs to exceed the RPM and KPH setting?
    Example, RPM = 6200 and KPH = 35KPH.
    So, once the rpm exceeds 6200 AND the speed is greater than 35kmh....the gear will change?
    Mar 2011
    That is my understanding
  1. T43 2010 2011 Missing Base Shift times and Diags
    By gmh308 in forum 6 speed/8 speed RWD/FWD Transmission Tuning (incl T43, T76, T87)
    Last Post: September 25th, 2011, 08:49 PM
  2. What is a HORSEPOWER FREAK?
    By HPF Fallon in forum General
    Last Post: June 17th, 2011, 09:42 AM
  3. Rear wheel horsepower PID - ?
    By Boost in forum Gen III V8 Specific
    Last Post: October 28th, 2010, 11:48 PM
  4. Need 2010 T43 SPEEDO support across the board....
    By Chuck CoW in forum 6 speed/8 speed RWD/FWD Transmission Tuning (incl T43, T76, T87)
    Last Post: August 8th, 2010, 12:17 PM
  5. Setting B3647...accurately..ish???
    By hquick in forum Custom Operating Systems
    Last Post: January 9th, 2008, 07:38 PM
