Results 1 to 3 of 3
Thread: calibration of fuel gauge
    Dec 2010
    Default calibration of fuel gauge
    its has been a while since i have posted and have had a few changes. I was trying to work on getting a better fuel reserve prior to empty light coming on. Originally, I had 6-8 gallons of fuel left when the empty light came on. I did some changes with my programmer and the changes were coming along just fine. The reserve was down to an acceptable 3 gallons. BUT, I had to change out the sending unit and found that the calibrations I had been working on no longer worked. In fact, with a bone dry tank, the gauge showed that I had a 1/4 tank. I tried to ensure that I had clocked the sending unit correctly (had to drop the tank again), but no way it can happen. It only goes in one way. Finally, I had found that the original sending unit measured from .8V to 2.8V. The new one measures no more than 2.5V. I figured this when I hooked up the wires to the unit with it out of the tank and the float level as low as it could go. The calibrations i had come up with were 2.5V = 6 gall left. The new unit does measure as low as .7V so I guess this is decent. But now I am having the same problem. About 4.5 gallons reserve. Too much for me. What can i do to fix this now? The only thing I can think of is to bend the float slightly. Also, when using the scan tool, it only measures to one decimal place. Can i change this to 2 decimal places to coincide with the tunig table? I know this is minor, but when you have a tiny tank (stock) every bit helps.
    thanks
    Jan 2012
    I am working on trying to calibrate mine as well. I noticed when full I have 98% shown on the tech 2 scan tool and 0.9V and when the low fuel light is on its 2.4V with 9 gallons of fuel left. ugh
    Dec 2010
    i recently changed the sending unit after SOMEONE dumped mud into my fuel tank. Well, now with the new sending unit and the stock voltage calibrations, I now have about 3 gallons left when the empty light comes on. I dont know why the difference, but I can live with 3 gallon reserve.
  1. 06 LLY Fuel Gauge - empty gauge with 7 gallons left
    By timvan in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: December 5th, 2009, 02:35 PM
  2. Fuel gauge calibration
    By PSWired in forum Gen IV V8 Specific
    Last Post: October 21st, 2008, 07:48 AM
  3. wacky fuel gauge
    By mr.prick in forum Gen III V8 Specific
    Last Post: April 14th, 2008, 02:47 PM
  4. Fuel Gauge And Volume
    By kds4791 in forum Diesel
    Last Post: February 21st, 2008, 03:09 AM
  5. Temp gauge calibration
    By Extinct in forum General (Petrol, Gas, Ethanol)
    Last Post: January 6th, 2006, 05:29 AM
