Results 1 to 10 of 10
Thread: Standalone reprogramming...
    Lifetime Member picnic_george's Avatar
    Jan 2007
    Default Standalone reprogramming...
    Is this going to be available anytime soon? Or is it and I'm not aware of it? LOL
    I've been hearing about it for a while and I would like nothing more than to just be able to press a couple buttons on my v2 and reflash my pcm to a different tune.
    May 2008
    Are you talking about the black box read/flash features? Those are available in the current release of efilive. If you want to actually edit the tune on the V2, I don't foresee that happening.
    E85 is NOT flex fuel.
    2003 Chevy S10 4.3L LU3 LS1B Auto
    48 LB injectors
    Race Proven Motors 2114 intake
    T70 turbo.
    Jan 2007
    Quote Originally Posted by nevinsb View Post
    Yes I am. I guess I need to figure out how then. Got a link to the info? I can't find it anywhere :( sorry.. I'd rather not wire a resistor into my IAT.
    May 2008
    In the 7.5 software, FILE > Save Tuning File for Remote Flashing. This will store it on your V2. Then you can go into the tuning menu on the V2 and flash/read tunes.
    48 LB injectors
    T70 turbo.
    Aug 2010
    Hello George,
    Attached is a somewhat dated document that outlines how to BBF with the V2. Some of the screen shots and menus have changed a little, but hopefully it helps you to get the gist of how to do use the V2 to flash your PCM.
    Regards,
    Taz
    Jan 2007
    I thought it was done through the BBx v 8.x. Thank you
    Quote Originally Posted by Taz View Post
    Hello George,
    Regards,
    Taz
    I'll check that out when I get to my laptop and see if it works for me.
    Thanks for the help guys
    Yes, use V8 software to configure the V2 for which PCM's you want to read/write;
    [ also use V8 to configure BBL pidlists ]
    be sure to use latest V8 build 170, and to program in firmware 2.07.22.
    Jan 2007
    Will do. I'm honestly not too worried about logging. I'm ok with using my laptop.
    Thanks, everytime I search switching tunes I always see the diesel stuff come up and I get irritated lol.
    Jan 2007
    10. Turn on the engine, put the gear in (1st or D), say “In GOD I trust”… and floor it and
    log the new performance data with your integrated SOPD device for further analysis.
    Your other options are GTECH or Dyno.
    LOL I can't wait to test the butt dyno. I assume "integrated SOPD device" is integrated seat of the pants driving device hahahahaha
    SOPD = seat of pants dyno
    every human has one of these integrated into their bod's, and some are more "calibrated" than others...
  1. Cummins Standalone?
    By wickedcummins in forum Do you want to be a Beta Tester?
    Last Post: January 12th, 2012, 02:41 AM
  2. E38 Standalone problems
    By GAMEOVER in forum E37, E38 & E67 PFI ECM's
    Last Post: April 26th, 2011, 04:49 PM
  3. E38 and E67 - GM Original Reprogramming
    By S10Wildside in forum E37, E38 & E67 PFI ECM's
    Last Post: May 2nd, 2010, 11:30 AM
  4. Standalone flashing before SEMA?
    By Hyper99 in forum FlashScan V2
    Last Post: March 1st, 2009, 09:09 PM
  5. Standalone DVT?
    By Cougar281 in forum FlashScan V2 BB Logging
    Last Post: July 12th, 2008, 01:58 AM
