Page 1 of 3 123 LastLast
Results 1 to 10 of 28
Thread: Air Density Adjust
    Jul 2011
    Default Air Density Adjust
    What does everyone do with these?
    How does the ECM average the tables between base and each Air Density table?
    Thanks..
    Lifetime Member Dmaxink's Avatar
    Nov 2009
    I leave mine stock (assuming your talking about table [E2554])...this table is a reference back to the other 1-4 timing tables as a reference of your altitude. So if your sea level (14.69 baro) you would be in table 1..rather it is in reference to timing or fuel pressure... I actually set all my tables up the same base, 1-4.
    -Kory
    I'm out of ideas? Nah trick... When in doubt, 0xFFFF it out!
    http://www.PPEI.com/
    Lifetime Member DoghouseDiesel's Avatar
    Dec 2009
    I do tweak mine to more realistic levels as the factory ones are pretty far out there.
    What I look at for air density is this. Make the tune for where you live, so like Kory said, you CAN pretty much make all the tables (1-4) the same, if you want. MOST of us don't travel that far from home and MOST of us don't go up or down more than 4000 ft to make that much of a difference anyways.....at least here on the east coast anyways.
    Factory tune...yeah, they gotta vary it quite a bit because they have to fit such a wide spectrum of operating environments.
    My air density gets calculated for approx 500' and I vary the temperature between 20 - 110*. That should cover me all year and I can go from here back home to NY and not have any major issues.
    For MY tune in the MY truck, most of my air density is calculated between .068 - .080
    1207 HP / 1612 TQ
    Jul 2011
    So if in a given year I drive my truck from sea level to 9K feet and vary in temps from -10° to 110° I should probably not have 1-4 the same?
    Just trying to understand some of the tables better.
    Thanks!
    Lifetime Member comnrailpwr's Avatar
    Jun 2011
    Correct, if your driving differs that much u need to adjust all tables to accomidate your desired adjustments. otherwise it will reference back to stock during altitude changes.
    Jake
    Nov 2009
    Maybe i misunderstood you Jake, but when the altitude changes.. it will just go on to the other table that represents its current density. Here is one thing to think of....typically it is our lower baro pressures that require the lower timing...so say if your 50%btdc timing (or whatever) works (no rattle) at low altitude..chances are you will not have problem at higher altitudes. At least in my experience...
    -Kory
    Dec 2009
    Quote Originally Posted by AH64ID View Post
    Thanks!
    Correct.
    The more varied the environment your truck gets used in, the more varied those tables will need to be to compensate for it.
    Hell, you're a pilot, I know I don't have to explain air density altitude and all that BS....you outta be explaining that here.
    If you look in the "Gift Tune" I posted, you'll see that all those tables are the same. Simply becuase that tune gets used here in Alabama and that truck really goes no where else except from Atlanta to Panama City, FL and the air density only changes by a maximum of about .012.....MAX
    1207 HP / 1612 TQ
    Jul 2011
    So if there is a base table and 4 altitude tables, does it blend the base and appropriate altitude table?
    Dec 2009
    No, it will use one table at a time.
    The only thing the ECM knows is the data it's fed. If the sensors says the density is .XXX, it doesn't look 1/4 mile up the road and see that we're still going up a hill and have the next map ready.
    If it was trying to use multiple tables for the same data it would be getting mixed signals.
    Let's think of the Cummins ECM like a man.....one track mind. It's time for breakfast, let's eat breakfast, no idea yet what I want for dinner.
    1207 HP / 1612 TQ
    Jun 2011
    Quote Originally Posted by Dmaxink View Post
    I was basically saying if he builds a tune for say sea level and doesn't touch adjustment in say table 4. his adjustments will not be present when he hits 9k feet because The ecm will take the commands from the unadjusted table, 4 in this example. I think I'm right, the truck I tune stays local and made them the same. But while we're on this whats the point of a base table if It'll always be using one of the altitude adjustment tables? Do we know when its using which one because I when efilive first came out I saw smartys tablets and I think theirs were stock? How would that work when that tune would change altitude? The smartys timing doesn't revert to stock upon altitude changes.. maybe I'm wrong and they were modified, haven't seen one in a while.
    Jake
  1. trying to adjust speedo ??
    By timvan in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: December 31st, 2009, 06:58 AM
  2. what to adjust for speedo???
    By newguy2diesel in forum Gen III V8 Specific
    Last Post: April 2nd, 2008, 04:24 PM
  3. Programming the Intake Air Valve for a Positive Air Shutdown
    By jpgmtech in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: June 20th, 2007, 01:38 AM
  4. AFR and air density altitude?
    By tgeers in forum General (Petrol, Gas, Ethanol)
    Last Post: August 15th, 2006, 01:14 PM
  5. Lower the CR and you should adjust...
    By eboggs_jkvl in forum General (Petrol, Gas, Ethanol)
    Last Post: January 17th, 2006, 03:45 PM
