Page 3 of 3 FirstFirst 123
Results 21 to 22 of 22
Thread: LS1 PCM on a 96 LT1 turbo motor.
  1. #21
    The tutorial assumes you will exceed the PCM's airflow limit.
  2. #22
    Nov 2007
    So on 10psi it made 600hp and 600ft/lbs. Not super impressive or anything, but I think above 10psi it will start to make more per psi, if the turbo still has some cfm in it. We didn't use the MAF cause the IAT sensor in it was dead, and the tubing went from 3" to the 4" MAF housing and back down to 3.5". So the readings wouldn't really be accurate cause of the turbulence. So I wired in the stock IAT sensor and we're using a speed density tune. So there is a dead spot if I mash the throttle. The is a little hesitation off idle that I think would be cured if I used a MAF. Here is the dyno chart. You can see the lean AF ratio right at the beginning. Click image for larger version.
    Also when I start the car while its cold and put it in gear it dies. So I think the idle needs to be elevated or something.
  1. Carbureted LT1 Runs on LS1 PCM
    By S10Wildside in forum Conversions / Aftermarket Parts
    Last Post: May 15th, 2014, 05:22 AM
  2. 06 Turbo LL8 Motor swap into a 240sx Preswap questions.
    By All4bspinnin in forum IL6,IL5,IL4 Atlas Engines - P12 PCM
    Last Post: December 3rd, 2010, 05:01 PM
  3. EFI Connection "24x" System and LS1 PCM for LT1/LT4 Engines
    Last Post: May 26th, 2009, 01:54 PM
  4. lt1 runs on ls1 computer using modded OPTI
    By akafred in forum Gen III V8 Specific
    Last Post: December 29th, 2008, 01:40 PM
  5. Lt1 => Ls1?
    By Cougar281 in forum Gen III V8 Specific
    Last Post: August 9th, 2007, 01:29 PM
