Page 1 of 7 123 ... LastLast
Results 1 to 10 of 68
Thread: Reducing injector wear
    Lifetime Member AdamRRT's Avatar
    Jun 2011
    Default Reducing injector wear
    I'd like to hear some thoughts on this. It ties into why we tune certain characteristics into or out of our tunes.
    A few times I've heard guys say that a single event tune will save injector wear by only firing once. I am not so sure. I think it'll help if it nets a lower overall total flow of fuel, causing less erosion.
    Anybody got any info showing that it's the actual act of the injector movement that causes failures rather than the flow at pressure as we already know as fact?
    EFI Live, Maxxed Out auto trans, Edge TC, FASS, 35's, 4" lift, E.D. 62/68/12, 70 hp tips.
    Dec 2007
    Quote Originally Posted by AdamRRT View Post
    A few times I've heard guys say that a single event tune will save injector wear by only firing once. I am not so sure. I think it'll help if it nets a lower overall total flow of fuel, causing less erosion. ?
    I work with high pressure, high volume, high velocity flow plumbing & valves everyday. Valves wear out from opening and closing them. The higher the pressure differential, the more you open & close them under pressure & the longer it takes for pressure to equalize around the valve, the faster they wear out. Valves in the open position very rarely fail.
    If you view the injector as a valve, this is one way to look at it.
    06 Laramie 3500 QC SB 4x4 - Full billet Auto by DTT, HE351/S475 twins, EFI live, lots of custom goodies....
    07 6.2L Yukon Denali - CAI, CAT delete, self tuned with EFI Live
    03 Trailblazer 4.2L I6 - CAI, custom exhaust, EFI live
    2010 Laramie 3500 CC LB 4x4 - H&S, DPF delete, waiting for EFI Live.....
    Mar 2009
    Quote Originally Posted by skneeland View Post
    Also keep in mind that a common rail injector doesn't work like a standard valve does. They open to spray by opening a bypass which causes a pressure differential that opens the valve. They are actually a dual action design.
    Jun 2011
    Yeah I'm not aware of the valve issue applying in our case. Unless someone has some info that brings that valve comparison into application.
    Sep 2011
    True , injector will open-close less. But the peak cylinder pressure will be higher. Will that cause more wear/higher duty cycle of the injectors? I don't know. Will it cause more wear of other engine components. I don't know, but it should be considered. Getting rid of the junk - 3rd injection event - is a good idea, but I think the pilot has a lot of good features and I plan on keeping mine (except maybe at idle just for some fun).
    Dec 2007
    regardless, it is still a valve even though it may not conform to your traditional ideas of what constitutes a valve.
    back to your original question, you may want to first look at better filtration. the stock 7micron filter system can easily be upgraded to a 2micron spin-on style (Bosch themselves recommend a minimum 5micron filter for this application)
    after that its also a good idea to modify the poorly designed vents on the top of the fuel tank (there is one at each end) that let in water when you drive & at the carwash...
    Jun 2011
    I can't see how you'd consider higher duty cycle when opening for a shorter duration overall per revolution. That means lower duty cycle. Unless I'm missing something. If so let me know.
    I think we will have reduced wear potential with EFILIVE. We can reduce our rail pressure to the min necessary pressure. Or ramp up early yet leave a safe ceiling like say make it so you're commanding 21,000 psi across the board, but limit it to that. Could in theory be tons of fun yet potentially not wear injectors as quickly. Just something I've always thought sounds like fun... On someone else's truck for 100k mikes first of course. Haha.
    Nov 2009
    I have a customer run 300k plus miles and so many engine hours the clock reset itself on stock injectors on a lbz Dmax that runs 12.60s...no this isn't typical as we would see a piston go by that time... but I have seen countless guys go 200k miles with a 3000+ uS... Dodge is a new ball game and now that they have good Tuning capabilities who knows how far they would go? My concern on injector wear would be high pressure in a smoking hot chamber... yet again... who knows how far they will go.
    -Kory
    http://www.PPEI.com/
    Jun 2011
    Quote Originally Posted by Dmaxink View Post
    So I can understand more... What part of it concerns u? Do you mean regarding predetonation?
    Nov 2009
    Reread my post..what I meant was before there would be an injector issue ( assuming fuel quality is good)...I wouldnt really be too worried about injector issues as I could see the truck dropping a piston or rod before injector issues would persist from tuning ect..high pressure high egts is the root of all evil, yet power :-) ...its that beautiful balancing act. Too much pressure without adequate relief would wear an injector more than anything in my book.
    -Kory
  1. Reducing torque for smoother city-cruising
    By carl0s in forum Gen IV V8 Specific
    Last Post: May 25th, 2011, 11:10 AM
  2. Reducing TM in a 2011 Camaro L99??
    By BowlingSS in forum E37, E38 & E67 PFI ECM's
    Last Post: December 6th, 2010, 01:26 PM
  3. Replies: 3
    Last Post: August 9th, 2009, 10:50 PM
  4. Reducing Smoke
    Last Post: July 10th, 2009, 03:22 AM
  5. Reducing "agression" of cruise control on hills?
    By endo in forum General (Petrol, Gas, Ethanol)
    Last Post: July 8th, 2009, 10:01 PM
