Originally Posted by
Ira
Open up EFILive Scan and Tune, then click the BBX button. Makes sure only the ECMs ad TCMs you're interested in are checked in both the tune and scan sections.
Then click the tiny arrow on the right edge of the program button and choose Format config file system. When that finishes, clear the dialog and then press Program. When that finishes, try again.
Oh, also make sure you're using Scan and Tune Build 170 and that your Autocal has bootblock 2.07.03 and firmware 2.07.22.
Ira
