Results 1 to 8 of 8
Thread: bbx wont read the engine tune
    Senior Member restless@westnet.com.au's Avatar
    Aug 2008
    Default bbx wont read the engine tune
    hi guys
    i have a slight problem v2 not reading the engine tune says error #050B script file not supported by current ver ??
    Ive just downloaded the latest up grades v7.5 and v8 and up graded the firm ware and boot block on the v2 ( wouldn't work with the old ver aether)
    all so i cant drag a tune file straight into the v2 from explorer any more ? says its not a ctd file ? it will go in but wont show up on the tune list on the v2 but does show up on tune in explorer ?
    its been about 4 months since i did any thing with the v2 and the car, was all good before
    i can up load a tune with pass through with the v2
    but the v2 still wont read it after its in the ecm ?
    cheers
    Aug 2010
    You need to:
    • format the Config File System in the V2
    • program Controllers to the V2
    • program PIDs to the V2
    Connect your V2 to your computer. Open V8 Scan and Tune. Select "F5: BBX". Select "F3: Tune". At the bottom of the screen there is a red "Program" button. There is a small arrow on the right edge of this button. Click on the small arrow and a 3 option pop-up menu will appear.
    Select the "Format Config file system" option. After this is complete, click on the small arrow again - this time select the "Program ALL Required Data" option.
    When this is complete select "F2: Scan". Select the "Program ALL Required Data" option.
    You should now be able to copy *.ctd tunes to your V2 - and flash these into a controller.
    Regards,
    Taz
    Aug 2008
    hi TAZ thanks a lot
    yes its all good now EXCEPT i still cant transfer a tune from explorer to the v2 i mustn't be doing it wright ? as i have never done it before with a v2 only with auto cal
    with v2 connected i highlight tune in the lower left column of explorer then left click on the tune in the upper half of explorer then drag it to the lower half of the page and drop it
    it says not a dtc file do you want to go ahead anyway ? i hit ok it transfers the file
    and it goes in some where( lights on the v2 flash ) and when i hit read it shows up
    but when i connect to the car and go to ( flash cal ) there's nothing there just says (read ) on the screen and it wont do any thing when i hit OK ?
    can you give me a walk through on that please
    everything else is fine now i can read the engine tune and it saves it as a # and can flash it back in from the v2 but i want to rename some tunes so i know which is witch
    thanks again
    bob
    From the V7 tunetool, did you save the .tun file as a .ctd file...?
    Can you post a screenshot showing what you're doing...
    Aug 2008
    no i dident it was all ready a dtc file from oz trac i thought
    i will email a page shot as i dont know how to post one here
    It has to be a .ctd file (not a .dtc file).
    Aug 2008
    yes i ment *.ctd* sorrey got it backwards is this the way its writen ( .*CTD* ) ?
  1. Cant BBX read Tune, I get error $050B
    By LS1_Dragster in forum FlashScan V2 BB Logging
    Last Post: September 11th, 2011, 01:25 PM
  2. VIN lic. wont read???!!!
    By 1badz2nv in forum FlashScan V2
    Last Post: May 25th, 2011, 03:48 PM
  3. help tune wont install
    By turfin8705 in forum Duramax LB7
    Last Post: August 26th, 2010, 12:38 PM
  4. wont read to 98 car will 01 car wtf?
    By 98redorangeta in forum Gen III V8 Specific
    Last Post: August 14th, 2008, 11:43 PM
  5. Read Check engine codes
    By Docfxit in forum FlashScan V2
    Last Post: April 21st, 2007, 10:59 AM
