Results 1 to 4 of 4
Thread: Changing OS in 99 C5 to 12212156
    Oct 2003
    Default Changing OS in 99 C5 to 12212156
    Can anyone tell me if there are any other problems (other than necessary tuning) when changing from 99 LS1 OS (9373372)to 2002
    Z06 OS (12212156). This is with the 99 PCM. (any pinout differences). Thanks for any input. Jim
    08 Z06
    Aug 2010
    Hello Jim,
    The 1999 and 2002 Corvette PCM pinouts are the same. If you are using the original PCM - full flash a 2002 Corvette tune - and tune from this point.
    If you are using a replacement PCM - make sure you change the VIN in the PCM to that of your Corvette - prior to first use. A VIN mismatch in the various modules used in a Corvette may cause intermodule communication issues.
    Regards,
    Taz
    Oct 2003
    Thanks Taz,
    I full flashed the 2156 tune (on the bench) and changed the VIN to the 99 C5. I am surprised that not changing the VIN would cause a communication problem.
    I also copyed and paste the tables in the new OS from the 99 (the ones where the X and Y axis were the same)
    The reason for the change is to make available the Z06 trans temp readout on the DIC. We have the temp sensor wired in but must use the Z06 OS in order to activate.
    Thanks for the info. Jim
    08 Z06
    The other modules might get upset if the PCM has the wrong VIN.
  1. 12212156 + Big Cam
    By SSpdDmon in forum Gen III V8 Specific
    Last Post: October 12th, 2011, 05:03 AM
  2. how do I go back to gm os 12212156?
    By Dark Halo in forum Custom Operating Systems
    Last Post: July 27th, 2011, 11:56 PM
  3. Looking for a 12212156 file
    By L31Sleeper in forum Custom Operating Systems
    Last Post: March 31st, 2010, 04:22 PM
  4. Will 12212156/COS5 run on PCM used in 2003 Z06...?
    By joecar in forum Custom Operating Systems
    Last Post: August 8th, 2007, 03:01 PM
  5. Update to the Camaro 02 OS 12212156
    By BowlingSS in forum Custom Operating Systems
    Last Post: August 11th, 2006, 03:35 AM
