Hello, I just got my Flashscan v2 and I'm trying to connect a analog WB. The problem I'm having is the voltage shows wrong in the external sensor display on the unit. It will not show higher than 1.2 volts. I see a calibrate menu choice but cannot find an explanation. I have upgraded everything to the latest firmware/boot block/software. Any ideas?
Thanks.
Norm
EDIT: Forget it. I found it.
