Results 1 to 6 of 6
Thread: What pid do i need for IDC
    Senior Member Behold's Avatar
    Apr 2010
    Default What pid do i need for IDC
    I want to understand my current injector's duty cycle. how do i monitor this???
    I have searched to no avail.
    Jul 2005
    RPM and IPW is all you need. the rest is math. no need to scan for it (read: waste your bandwidth), if you can just do a custom PID for it.
    Apr 2010
    Thanks...
    And which thread is waste your bandwidth. I cant find it....
    Jul 2005
    IDC, you can scan for it, but that most likely uses up bandwidth (I don't have the software in front of me, cant verify it), unless the default IDC PID is a calculation itself. If that's case please ignore me, and thank EfiLive crew on doing things right
    Which year/model/vehicle do you have...?
    If it has an LS1 (Gen III) PCM, then you need these specific pids: RPM, IBPW1/2 and INJDC1/2.
    Apr 2010
    Thanks Joe. I do have an LS1B PCM. I have added IBPW1/2 and INJDC1/2 in my V7 fields to populate in my scan.
  1. Convert Pass Thru Scan PID list to BBL PID list
    By jrh in forum FlashScan V2 BB Logging
    Last Post: July 5th, 2011, 08:09 AM
  2. e38 dma pid SCALEDCORVE_ doesnt work plus a bad calc pid
    By ringram in forum FlashScan V2 BB Logging
    Last Post: November 30th, 2008, 11:28 AM
  3. Rising Rate Reg (2:1) and IDC/IFR
    By JezzaB in forum Gen III V8 Specific
    Last Post: August 16th, 2007, 07:40 PM
  4. Which PID's for power PID's to work
    By ViolatorTA in forum General (Petrol, Gas, Ethanol)
    Last Post: June 4th, 2007, 01:47 PM
  5. Estimating total fuel flow from IDC
    By mistermike in forum General (Petrol, Gas, Ethanol)
    Last Post: May 30th, 2006, 04:16 AM
