Results 1 to 10 of 10
Thread: # of pulses table?
    Oct 2010
    Default # of pulses table?
    On my 07 LMM there is a table for # of pulses. What is that for and do? Original tuner didn't touch them but another tuner changed the whole table to 2. Anybody know what this table does and is for? And don't say it sets the number of pulses lol.
    Lifetime Member Dmaxink's Avatar
    Nov 2009
    This is for your pilot/post injections... if you look on the top right in the "descriptions" it tells you what the numbers mean. Basically, how many injection events you will allow
    -Kory
    I'm out of ideas? Nah trick... When in doubt, 0xFFFF it out!
    http://www.PPEI.com/
    Oct 2010
    I understand that but i'm not understanding how it fits it. I mean I thought when the injector fires for say 2500us, thats one event. Why would you need or want multiple events?
    Nov 2009
    it is for emissions purposes...ex. Pilot injection is mainly for noise emissions. Stock setup would typically only run the main event after 2800rpms or so to help on the fuel pressure side of things and allow more time for the main event (event that creates the power)
    -Kory
    Oct 2010
    Ok I kind of see. You know why the tuner would have changed the whole talbe to 2? Some of the stock values are like 5. Everything runs good, i'm just trying to learn about all this.
    Nov 2009
    1 is main injection, 2 is your pilot, 3 is a pilot youll see pop up time to time, and 4 is a post event, as is 5 but thats supposed to be used during regen i believe... setting it to 2 will only allow that main and pilot... that is all i typically set them up at and then main only on the big side.
    -Kory
    Oct 2010
    Ok sweet great explaination. Thanks.
    Nov 2009
    -Kory
    Oct 2010
    Ok bud one more question. OK i've been having a problem with transient tables, my timing and probably my vane % follow my transient table and then slowly work it's way up to following regular tables after a few min. But it's at steady cruising. You know the purpose of them, I know the theory of when in transition it will use them, but i've read it uses them very shortly. I'm in the transient tables most of time. I mean you build a timing table so there really isn't a purpose to using transients anyways, I just copied my low alt tables and put them in my transient tables.
    Jan 2008
    One thing to add is that table is there to protect the ECM and injectors as well. you will see that there is a voltage reference on one of the axis. If the ECM is not receiving enough voltage from the alt/batt it turns down the amount of times it can open and close the injector for one stroke of the piston. The injector it self becomes sluggish and slow to respond if not provided with optimum voltage to actuate it. So, as voltage decreases so to the events available.
  1. Calc.VET: correcting MAF and calculating VE (in single log)
    By WeathermanShawn in forum Gen III V8 Specific
    Last Post: February 20th, 2023, 04:55 AM
  2. Tacho Pulses
    By eboggs_jkvl in forum E37, E38 & E67 PFI ECM's
    Last Post: May 12th, 2011, 10:08 AM
  3. RPM pulses from V6 to V8 swap 2001
    By onegonewild in forum Gen III V8 Specific
    Last Post: June 7th, 2009, 07:43 AM
  4. Crank Pulses how many?
    By chevy052500hd in forum IL4, 97-01 PCM and 02+ P11 PCM
    Last Post: December 29th, 2008, 11:48 AM
