Results 1 to 2 of 2
Thread: Lean on stomp
    Feb 2008
    Default Lean on stomp
    can someone help me with the lean spot on stomp. you can hear it pop every now and again through the intake if the engine is around 150 F or so.
    Jan 2007
    Do a quick search for 'lean tip in'.
    Howard
    DUCT TAPE.
    98 K1500 'HOLDEN' Suburban.
  1. what is too lean?
    By smslyguy in forum Gen III V8 Specific
    Last Post: May 17th, 2011, 02:53 AM
  2. Stomp Compensation and Impact Factor, whats the difference?????
    Last Post: November 12th, 2009, 07:07 AM
  3. can a lean idle or going lean during light cruise harm the engine?
    By ryans1000 in forum General (Petrol, Gas, Ethanol)
    Last Post: November 3rd, 2009, 01:44 PM
  4. Stomp or Impact
    By mr.prick in forum Gen III V8 Specific
    Last Post: October 8th, 2009, 12:04 PM
  5. How lean can I go?
    By dirt_track_racer_81 in forum General (Petrol, Gas, Ethanol)
    Last Post: June 18th, 2006, 07:47 PM
