You think that just 100mV would make that much of a difference?
2007 5.3l Tahoe. K&N CAI, Pacesetter LT/ORY no muffler, vette servo, Tru-cool 40k, Innovate LC-1 wideband, 3.42's Circle D 3k, 100shot
Slowly learning how to tune via EFILIVE
No hard feelings. Im actually trying to figure out and fix some of the things my first tuner changed. Some of the things he did were not good..
oh you would be surprised, i did an experiment once with values similar to yours and it caused major problems with ltfts and since you have a flex fuel having really messed up fuel trims is going to cause havoc with the computer logic in regards to determining what percentage of ethanol is in your fuel.
i compared the tune you posted up with a stock version of that tune and i would set B3671, B1515, B1516, B1967-B1975, B2012 back to stock values.
03 Silverado 5.3 ECSB 4x4 Z71
Comp Cam 206/212 .515/.522 112 lSA, hardened rods with LS9 springs
2010 Tahoe VVT AFM 5.3
Stock for now
Sounds like your on the right track.. Im going to try out what you suggest and see if the LTFTs straighten out..
yeah did he setup the spark map? a general rule is that you don't want more than 3* max of change from cell to cell. its going like 10* of change over like 2 cells, i wouldn't mind seeing a good wot log to see what cells you are hitting. Was the spark map tuned on a dyno or guesswork?
Stock for now
It was pretty much all guess work. I set up the low load low thru high rpm values to 33* because it was 50-60* in those areas. I was getting KR so i kept lowering those cells till i got no KR and the engine felt smoother. Wot is fine. Im at 24.5* timing and 12.5 ish AFR with no knock
Gregs,
I changed the tables that you told me to change. Flashed it in, reset the fuel trims and went for some logging..
Heres what I got-
Tahoe fuel trim6.efi
