Lets see if I can attach it here...
Cummins Timing Calculator v2 Modded.zip Let me know if it works correctly for you guys. I should also add that it is set up for timing tables that have the 20 degree bias added in, so if you are using the beta software without the bias, you should just add 20 to your values. It will spit out your total timing for pilot and main actual. (meaning the table it spits out will have the 20 degree bias subtracted already, and your values should be true to what is actually happening) Like I said, just let me know if it is working correctly, and if it isnt I may be able to fix it.
Les, its also in your inbox unzipped.
