Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 42
Thread: Silver Bullet Tuning makes 625hp smoke free.
  1. #21
    Lifetime Member AdamRRT's Avatar
    Jun 2011
    Quote Originally Posted by someguy View Post
    Meaning he could use over 600 HP continuously, all day and not have any EGT issues, even at WOT ?
    I don't understand this then.
    If you can get it hot (1500F) racing to 110 MPH, why wouldnt it get hot towing ?
    600hp is at WOT. There's absolutely no reason he'd be running at WOT all day long. That's not realistic. Remember we can change how it fuels at each point of the pedal.
    EFI Live, Maxxed Out auto trans, Edge TC, FASS, 35's, 4" lift, E.D. 62/68/12, 70 hp tips.
  2. #22
    Nov 2010
    As explained above...NOBODY tows at WOT. I built the tune to make power on the street...if it needs tweaking to keep the EGT's under control...then so be it.
    His turbo, injector and tuning choice will allow his to tow all day with a truck that makes over 600hp all day long. Its a simple fueling adjustment (if needed) to pull fuel back when under HEAVY load to bring the temps down (IF THEY ARE HIGH).
    Les Szmidt
    2007 5.9 Dodge Ram
    EFI Live Cummins BETA Tester
    silverbullettuning@gmail.com
    www.youtube.com/ljszmidt
  3. #23
    Oct 2011
    He may not be at WOT all day long, but give him a 14,000 pound trailer and an 8% grade and he needs 400 HP to maintain 60 MPH. Throw in a headwind and you are at 450 HP. Can it run there without EGT issues ?
    Thanks !
    BTW: I think what you are doing is awesome and the fact you can get so much power while being smokeless is double awesome. Great work and thanks for sharing.
  4. #24
    Nov 2010
    Yes...the turbo map is favorable to towing heavy and keeping temps cool. My interpretation of cool is 1250-1300*@40psi
    Alot of how something tows is on the drivers seat....foot control, gear control etc...I can tow 14,000 with my 66mm if I want, I'd just need to adapt my driving style to be conducive to what I am doing.
    Les Szmidt
    2007 5.9 Dodge Ram
  5. #25
    Lifetime Member DoghouseDiesel's Avatar
    Dec 2009
    Les,
    If I hitch up 8 regular reindeer and one with a rednose and put one fat bastard in a sleigh going over the Himalayas with ALL THE TOYS IN THE WORLD, which reindeer would run out of breath first?
    Now, lets make it 10 reindeer and lets go a little faster, now which reindeer runs out of breath first?
    1207 HP / 1612 TQ
  6. #26
    Oct 2011
    Do you use the turbo map or do you use boost as a limiter ? Or both ?
    What kind of boost can you get with the VGT (with decent timing) at 1700 RPM ?
    I cannot wait to start tuning my 6.7 !
    Thanks !
  7. #27
    Nov 2010
    Quote Originally Posted by DoghouseDiesel View Post
    Les,
    Unfortunatly here in California we are limited to 8 regular raindeer and one red nosed one.
    Adding another would make it much easier but smog dictates and Highway Patrol says otherwise
    Les Szmidt
    2007 5.9 Dodge Ram
  8. #28
    Nov 2010
    Thanks !
    Both...I build my setups to utilize the sweet spot of the turbo map for DD and towing and the right side for peak hp goals.
    Les Szmidt
    2007 5.9 Dodge Ram
  9. #29
    Oct 2011
    I didn't get the reindeer analogy. Just saying.
  10. #30
    Nov 2010
    I understood it as rich was saying that twins are the best of both worlds. Here in Ca, smog laws won't allow for twins, so we need to do our best with a single turbo.
    Les Szmidt
    2007 5.9 Dodge Ram
  1. What makes a smoke tune?
    By pavetim in forum General (Diesel)
    Last Post: December 22nd, 2010, 07:52 AM
  2. What makes the difference of efilive
    By jennbab3 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: June 24th, 2009, 06:35 PM
  3. Donor Vehicle wanted-Free Tuning-PHOENIX
    Last Post: April 11th, 2009, 07:32 AM
  4. Programming Silver PCM from 2001 S-10 4.3L to handle 97 Vortec
    By onegonewild in forum Gen III V8 Specific
    Last Post: May 1st, 2008, 02:42 AM
  5. New L92 427 w/625hp is cheaper than messing w/5.7liter GenIII
    By 98 tigershark in forum Gen III V8 Specific
    Last Post: November 24th, 2007, 12:17 AM
