Results 1 to 3 of 3
Thread: Part throttle shift table conversion?
    Lifetime Member 67SS509's Avatar
    Dec 2005
    Default Part throttle shift table conversion?
    In the transmission KMH vs TPS shift table is there a way to convert from KMH to MPH? Sure would be a lot easier adjusting this table if it was MPH.
    In tune tool, go Edit->Configure Display Units, select the rows you want to change, and press Imperial.
    You can press on each of the headings "Data Units", "Col Units" or "Row Units" to sort on that column so all the km/h's (for example) will grouped together, and select all the rows in each group, click Imperial; do this for each of the 3 headings (Data. Col, Row) as km/h appears as data, columns, and rows in various different tables. Then when done click Ok, and restart the tunetool.
    This is how I can have mixed units (e.g. g/s, kPa, MPH, ftlb...).
    Cheers
    Joe
    Dec 2005
    Thanks....worked for me
  1. For those who are having Idle and Part-Throttle Surging
    By RacerChris in forum Gen III V8 Specific
    Last Post: November 20th, 2008, 03:17 PM
  2. Truck feels sluggish at part throttle
    By Aint Skeered in forum General (Petrol, Gas, Ethanol)
    Last Post: June 9th, 2007, 05:52 AM
  3. Proper way to raise part throttle shift points
    By Redline Motorsports in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: September 16th, 2006, 01:44 PM
  4. Part throttle downshift.
    By 12sec.5.3 in forum General (Petrol, Gas, Ethanol)
    Last Post: June 18th, 2006, 10:42 AM
  5. Adjusting idle and part throttle
    By Silver02 in forum General (Petrol, Gas, Ethanol)
    Last Post: June 10th, 2005, 02:16 AM
