Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: turbo tuning?
    Jun 2011
    Default turbo tuning?
    Since I only have a stock turbo now, I haven't had to worry about spool up. I am considering a 64 or 66 turbo and a set of 90hp injectors, but I do tow with this truck and need to keep good low rpm spool and power. Ultimately I am chasing the 650hp area, so I need some good airflow.
    What I am wondering is from those that have tuned a larger single with EFI, how do they spool? Can you tow with them and keep some low end power? I know that a larger single is not an ideal towing turbo, but I figured with how we can control timing and duration so well that it is doable?
    Thanks!
    06 CC DRW, DTT, EFI Live.
    473HP
    Nov 2010
    Timing is KEY for spooling...keep it low until boost comes up then bring it in to add power.
    I'm running a 66mm and 90hp injectors...and I'd have no problem towing 10k.
    Les Szmidt
    2007 5.9 Dodge Ram
    EFI Live Cummins BETA Tester
    Silver Bullet Tuning
    silverbullettuning@gmail.com
    www.youtube.com/ljszmidt
    Jun 2011
    So when do you start to get decent boost, like 1600 rpm?
    473HP
    Nov 2010
    With proper throttle control I can have 10psi by 16-1800 and full 50psi by 2100
    Les Szmidt
    2007 5.9 Dodge Ram
    Lifetime Member FUBAR's Avatar
    Feb 2011
    Quote Originally Posted by 2007 5.9 View Post
    Something I want to try to point out here. Les's setup is less than ideal for towing heavy on a hot tune..well, that WAS the case with previous box tunes. You had to reflash the truck with a different, "tamer" tune on the box tune. A lot of people think this is still the case with EFILive and are holding off using EFILive till the Switchable Tuning comes out. I am here to say, from a experienced user's standpoint of switches with Duramaxes, it is not needed. Handy? Sure. It has it's place. BUT YOU can have your cake and eat it too!! Provided you know what your doing, it IS possible hit the track and then the fields to tow your round bales of hay around without "de-tuning."
    Same goes for if starts to sprinkle a little rain. You don't have to have a heart attack that your truck's gonna go careening sideways off the road because of the hot box tune you're running to support your higher hp truck. EFILive makes it possible to tune all that garbage out IF you know what you're doing or if you let one of the finer tuner's on here handle it for you and develop a good repore with them and learn.
    -Andrew
    06 5.9L, EFILive / Silver Bullet Tuning
    06 LBZ, EFILive
    Nov 2010
    Quote Originally Posted by FUBAR View Post
    -Andrew
    Well said Andrew!!!
    Les Szmidt
    2007 5.9 Dodge Ram
    Lifetime Member AdamRRT's Avatar
    Jun 2011
    So Les, just cause I'm also just learning where optimal timing can be, I love this topic.
    YES I've noticed that a stock timing table comes in a couple degrees ATDC in the low end. When you say keep timing low, can you give a rough idea of where you like that timing? Like say for towing we'd do what, 80-100mm3, 750-2000RPM, and 50% TP%? Just as rough numbers. You changing that range would be even better so I know what you mean. I'm really trying to find the best area. I KNOW when I took my tune from 5* BTDC and moved it to 0-1* BTDC, it spooled faster from just that little bit.
    And if I'm not mistaken, if we added a little timing down low, to just before we start losing power (found by sweet spotting on the dyno of course), we'd pick up a small bit of fuel economy due to the more complete burn, but we'd also lose some power cause of the slower spool. Am I even right on this as I understand diesel injection timing?
    FUBAR - I agree. It's so nice to know we can have economy from 0-33% TP%, towing from 34-85% TP%, and performance from 86-100% TP%. Theoretically.
    EFI Live, Maxxed Out auto trans, Edge TC, FASS, 35's, 4" lift, E.D. 62/68/12, 70 hp tips.
    Nov 2009
    I actually enjoy driving the hopped up 5.9s in my area now :-)...before it was strictly..."ehh lets take my truck". lol
    -Kory
    http://www.PPEI.com/
    Jun 2011
    So with the timing control, there should be no reason that I couldnt tow in the mountains with a 64? Sounds pretty cool. Guess that I will just have to buck up and buy the stuff, try it and report back!
    473HP
    Lifetime Member DoghouseDiesel's Avatar
    Dec 2009
    Quote Originally Posted by mstordahl View Post
    Well, look at it like this, my twins are 64 over 80 and I don't change a thing from daily driving to towing to track except the tires.
    With my little 37 lpm injectors and normal driving, I'm making 6 - 8 psi of boost at 1600 rpm's.
    Hook any of the trailers up and boost is instant. It likes having the extra load on the motor vs unloaded. Towing the flat bed (3700 lbs) with another truck (6800 lbs) on it, cruising at 80 mph and I'll be sitting at 14 - 16 psi and 850*.
    1207 HP / 1612 TQ
  1. Turbo Tuning Help
    By jckleewein in forum General (Diesel)
    Last Post: August 30th, 2009, 06:11 PM
  2. sts turbo tuning
    By xAustin in forum Vortec V6/V8 Specific
    Last Post: September 6th, 2007, 07:39 PM
  3. AutoVE tuning with turbo
    By WicketMike in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: September 3rd, 2006, 09:22 PM
  4. Turbo Tuning
    By WicketMike in forum General (Petrol, Gas, Ethanol)
    Last Post: January 21st, 2006, 07:43 PM
  5. Turbo & Tuning
    By lplott in forum General (Petrol, Gas, Ethanol)
    Last Post: August 25th, 2005, 02:55 AM
