I finally decided that it is time to let the Smarty go so I removed it today and did a full flash with the Christmas tune and had a problem entering my vin at the end of the flash. I finally got myself straightened out, changed the vin to my vin but now my rear window/mirror defrost light in the button is flashing. So I'm not sure what went wrong so if any of you guys can help me out it would be appreciated.
When I couldnt get the vin to change I did not start the truck but I did turn the key on and off a few times to connect the flash scan so I'm not sure if that has anything to do with it. The truck does run and seems to be fine other than the light is flashing. As of now the stock tune is loaded in the ecm.
