I'm sure there's more power to be found in the current setup but this is were I'm at. This is a friend's 2006 truck, he's very happy with how it's performing so far! The only upgrades are a 63mm charger and headstuds, otherwise it's a stock motor. Boost hits 50psi, RP max is set at 24,000psi, egt's max out at 1250*F in the manifold and post injection has been eliminated.
