Results 1 to 6 of 6
Thread: Issues with locking ECM then flashing again
    Lifetime Member LBZoom's Avatar
    Jun 2008
    Default Issues with locking ECM then flashing again
    Hey guys,
    So I've attempted my first bench program in which I actually attempted to "lock" the ECM using my own key..... during the flash process it said "invalid key was entered ECM will remain unlocked"
    So, when I went to try again it won't flash now, it keeps saying it can't unlock it I guess..... what do I do know?! At least the tunes made it in okay but am I dead in the water to make any changes to it?
    I'm sending this one to a customer.
    Peace Through Torque
    Punisher Performance DSP5 Tuning, PPE Dual CP3's, 68mm Fleece Cheetah, Punisher Built trans w/ Suncoast Parts, Airdog 165, SoCal 100% Overs, ARP Studs
    2013 NHRDA Sportsman World Champion
    www.PunisherPerformance.com
    Jun 2008
    This is an LB7 ECM also in case it matters
    Jun 2008
    I can change the vin, no problem there....
    When I go to do a full flash it allows me to enter my custom lock key that I choose, which was 10 digits..... however, when you enter the key to unlock it then, for reading or flashing it only allows you to enter 5 digits/letters.... I believe this may be my issue.... this is very frustrating!
    Dec 2005
    Try entering the first 5 digits only
    www.mscservices.net
    Jun 2008
    Tried that also, caps, lower case, you name it!
    Jun 2008
    Here's the link that solved the problem for me, not sure why it's a recurring issue but at least it's fixable!
    http://forum.efilive.com/showthread....e-a-key-for-it
  1. locking ecm
    By SGFastMax in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: July 13th, 2010, 09:00 AM
  2. Flashing ECM Alone?
    By Nemo in forum General (Diesel)
    Last Post: April 12th, 2010, 09:18 AM
  3. locking/unlocking issues
    Last Post: July 13th, 2009, 12:32 PM
  4. Locking ecm
    By IdahoRob in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: July 19th, 2007, 02:10 PM
