How do you log lambda instead of AFR when using the analog inputs? Do you have to add a calculation line after the AFR line of CLC-00-955 to the sae_generic.txt file? Thanks.
# Dynojet WBO2
*CLC-00-955
V 0.0 5.0 .1 "{EXT.AD1}"
AFR 10.0 20.0 .2 "{EXT.AD1}*1.6+10"
*CLC-00-956
factor 0.0 2.0 .2 "{CALC.AFR_DJ1.AFR}/{GM.AFR}"
*CLC-00-957
V 0.0 5.0 .1 "{EXT.AD2}"
AFR 10.0 20.0 .2 "{EXT.AD2}*1.6+10"
*CLC-00-958
factor 0.0 2.0 .2 "{CALC.AFR_DJ2.AFR}/{GM.AFR}"
