Results 1 to 9 of 9
Thread: No Fuel Level After Flash
    Oct 2011
    Default No Fuel Level After Flash
    Hey guys, scanned the p08 off my 99 s10 4cyl and had a little trouble uploading my edits so ended up using a full reflash. After the flash the fuel level on the dash is not working. I notice the Fuel System has no calibration tables on this tune. Can anyone provide a file that does have the calibrations (flex fuel 2.2?) or perhaps some way to return the stock settings? Or is this related to VATS somehow? Thanks, Mike
    Aug 2008
    Have you tried disconnecting the battery for a couple of minutes???
    FLASHSCAN V2 & AUTOCAL
    Oct 2011
    No luck after disconnecting battery. Whats next?
    May 2010
    What tune did you full flash in? Can you post it?
    1997 S10, 06 trailblazer SS LS2 swap, 4L70E trans, 76mm turbo. Factory ZQ8 suspension. 3.08, G80 w/a zexel. With a 0411 swap.
    Oct 2011
    No problem, only changes made were to emissions reporting and speed limiter.
    May 2010
    G0915 is your problem. Read the description in the top right hand corner. That whole column is not supposed to be disabled. Enable the third line down. More than emmisions reporting and speed limiter has been changed in that tune. Just saying it is not a bone stock tune.
    I agree with Slows10, the 4cyl PCMs share a lot of code with the P10s and my stock P10 file (and all tunes as they arent swaps) have a few of the Platform Options enabled from GM. Thats not a stock tune, or someone has modified it to run standalone.
    Oct 2011
    OK great info, my friend was messing with the computer I'm sure he changed a few things I missed thanks guys.
    Oct 2011
    Reflashed it tonight fuel works again thanks guys.
  1. Fuel level gauge issue after tune...
    By bline in forum Gen III V8 Specific
    Last Post: May 11th, 2011, 06:45 AM
  2. Replies: 1
    Last Post: September 22nd, 2010, 03:40 AM
  3. E38 fuel level sensor calibration
    By harascho in forum E37, E38 & E67 PFI ECM's
    Last Post: November 29th, 2009, 03:39 PM
  4. DSP5 wont take flash? Fuel vs Speed does not work?
    By Mitco39 in forum General (Diesel)
    Last Post: August 13th, 2009, 10:12 AM
  5. Fuel Level Sensor Primary F0101
    By Schweinmesser in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: February 10th, 2009, 05:01 AM
