Results 1 to 10 of 10
Thread: Stall Converter unlocks when cruise is enabled.
Hybrid View
    Junior Member hsv084's Avatar
    Jan 2010
    Default Stall Converter unlocks when cruise is enabled.
    Hi All,
    I have a Holden Commodore VY SS with an LS1 and 4L60e. Problem is I can't work out why my converter won't lock in cruise mode. I can be in either Normal or
    Performance mode with the converter locked but as soon as I engage cruise control it unlocks the converter, then as soon as i disengage the cruise control it will
    lock straight back up. Any ideas would be great.
    Regards Jeff
    If you want more inches stroke it
    Check the Cruise columns in the TCC apply/release tables...
    in each table make the Cruise column the same as the Normal column and try it out.
    Jan 2010
    Sorry for the delayed reply. Thanks for the suggestion Joecar, No joy though. I made my cruise tables the same as normal mode and still it wont let or keep the converter locked in cruise mode. Any one had this issue before. The PCM is controlled by EFI Live OS5.
    Regards Jeff
    Post your .tun file.
    Jan 2010
    Hi Joecar,
    Here it is
    Regards Jeff
    I would also set the Throttle Kickdown tables to all 100% (to avoid interfering with the PT up/down shift tables).
    Jan 2010
    Default Thanks
    Thank Joecar, I'll try it tomorrow and see how it goes.
    Set the TCC Throttle Release tables to all 100% (otherwise these will interfere with the part throttle TCC apply/release tables).
    Jan 2010
    Sorry to re-open this but still having issue. Tried the above fixes with no result.
    Here is the latest tune. Any ideas would be great.
    Look at the TSTATEnn pids (do rightclick->More Info on each) and log the one(s) that show TCC unlock reason.
  1. GEN IV swap AFM is not enabled
    By harascho in forum Gen IV V8 Specific
    Last Post: January 29th, 2009, 07:01 PM
  2. TCC unlocks slips
    By 4wheelin in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: December 7th, 2007, 01:29 AM
  3. Lean Cruise and Cruise Control
    By neil in forum Tuning For Economy
    Last Post: July 9th, 2007, 09:42 PM
  4. Stall converter
    By Chevvy SS in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: September 30th, 2006, 08:37 PM
  5. Tuning for a 3000 stall torque converter
    By dirt_track_racer_81 in forum General (Petrol, Gas, Ethanol)
    Last Post: June 5th, 2006, 03:03 PM
