I am doing an 05GTO/4L into a El Camino, and need to make up a small fuse panel. [The first E40 conversion I've done.]
I am unsure which circuits I need to put fuses in. [The guy that removed the engine/harness cut it off at the oem fuse panel, and didn't take the under dash wiring out. He also cut the harness to the J1 plug off under the dash.]
I've got all the wires in the J1 identified and tagged. I now need to be able to power it up. [Using the Alldatadiy drawings]
The OEM fuses indicate there are:
2 - 15A for the LH and RH injs and coils.
2 - 15A for engine sensors and auto trans.
2 - 15A for engine control/BCM and fuel pump.
Not sure this is all I need.
NE1 "unfortunate" enuf to have done this, that would be willing to shoot me a list of the fuse locations....NE is appreciated!
[Speartech makes a J1 "quickie" plug/play harness... Customer is not liking the idea of the $$.] However, much more time "patching" this together, may put a new harness in a much better light! Right now, I'm suffering from PC withdrawals from searching....
