Right now lockup is set at 43, locksup fine, pressure is fine, solenoid seems to pass the fault test, if i go below the release speed (41) TCC releases without issues, if i hit the brake pedal, TCC releases, if i manually shift into D3 (NO lockup), TCC releases...
every now and then (intermittent problem), the TCC will NOT release if i press the pedal past the 'breaking' point....ie if i smash the pedal to the floor gradually or instantly (verified 100% tps via efilive), the TCC still won't release...
i can't seem to track down the X factor though...
any ideas what i should be logging in order to figure out what the issue is?
oh and this never happened until a few days ago when i lowered the lockup apply speed. i'm going to set the previous tune in and see what happens...
PS: this is in my 94
