Results 1 to 4 of 4
Thread: Screwy Problem From Tuning LB7
    Dec 2006
    Default Screwy Problem From Tuning LB7
    I have truck that I am remotely tuning, and this issue has come up. This is a towing tune.
    With the stock tune in the truck, the truck is fine and every thing works great, Once he uploads the modified tune, the truck has the following problem.
    If you are cruising down the highway with the cruise control on and decide to turn the left directional on the cruise control is turned off. Only happens with using the left turn signal.
    If he loads the stock tune back in the problem goes away.
    Any ideas on this.
    Wish I could help but thats the first time I've heard of that...
    2004.5 LLY Duramax, Compounds, EFILive, EvolvedMS.com 50" Trac Bars, DDP Injectors, PPE Pump, 4" turbo back exhaust, 6" Chrome Stack,
    ATS Trans w/ Triple Loc.
    Evolved M.S, LLC & SS Diesel Tuning
    Lifetime Member Dmaxink's Avatar
    Nov 2009
    Are u using the same OS as the original?
    -Kory
    I'm out of ideas? Nah trick... When in doubt, 0xFFFF it out!
    http://www.PPEI.com/
    Dec 2006
    It is the same os, his factory tune, only a few tweaks for improved towing
  1. Lb7 dsp5 defuel problem help?
    By DMAXTIM in forum Duramax LB7
    Last Post: July 14th, 2011, 02:21 PM
  2. lb7 tuning
    By SGFastMax in forum Duramax LB7
    Last Post: June 8th, 2009, 01:51 AM
  3. SD tuning problem
    By PladdPezzPunk in forum Gen IV V8 Specific
    Last Post: August 27th, 2007, 10:27 AM
  4. Custom OS went screwy?
    By slowhawk in forum Custom Operating Systems
    Last Post: October 3rd, 2006, 10:29 AM
  5. 2002 Duramax LB7 Tuning Pow Wow
    By snooz in forum General (Diesel)
    Last Post: January 21st, 2006, 10:18 AM
