Results 1 to 2 of 2
Thread: Adding fuel
    Oct 2005
    Default Adding fuel
    I understand that I can add fuel by:
    - raising the fuel pressure (B1001)
    - increasing the main inj. pulse (B0720/B0721)
    BUT isn't the B0720/1 some sort of calibration and the true command to inject more fuel is coming from B0727?
    Several tables are defined up to 100mm³ others up to 110mm³ (timing)
    B0727 accepts values of up to 200mm³, how can those be handled e.g. in the tables B1001 or B0720?
    Quote Originally Posted by Lennart
    Well, seeing as though no-one else answered.
    Because B0720/1 only go up to 100mm3 it does seems odd that you would put more in B0727 when the injector pulse table will limit you to 100mm3.
    So to answer your question, right now, adjusting the pulse width in tables B0720/1 is the only way to add more fuel once commanded goes above 100mm3.
    Unfortunately altering these appears to skew the DIC MPG readings.
  1. Adding logs together?
    By hquick in forum General
    Last Post: July 21st, 2010, 02:42 AM
  2. Adding O2's
    By jsm00z28ss in forum Gen III V8 Specific
    Last Post: December 30th, 2009, 09:34 PM
  3. COS#3 adding timing
    By minytrker in forum Custom Operating Systems
    Last Post: November 26th, 2008, 05:39 AM
  4. Adding Headers and expected Fuel trims
    By Beer99C5 in forum Gen III V8 Specific
    Last Post: April 25th, 2007, 01:35 PM
