Results 1 to 6 of 6
Thread: Tire change
    Dec 2005
    Default Tire change
    Has any one tryed doing a 6a tune with smaller tires with any luck.I put some 275 40 17 hoosers on my 2010 camaro very small thinking I can use them for drag racing then use org tires still for street driving and not changing gears.
    I have tryed changing trans tune and ecm tune like 10 times I cant seem to make the abs happy, the stability trac is not happy eather but i can click it off.
    I have tryed speedo setting in both controlers drive tire settings ect.
    Then seen some stuff about abs module needing programed for gear changes ?
    I have done 4th gen stuff never had the problem getting around it
    or do people just pull the abs fuse lol seems like a good idea right now
    I have done some searching on forums havent found anything
    Dec 2005
    help lol any one change gears and have abs come on ?
    If the tire size is different than original, the ABS module will be unhappy about it;
    ABS module needs programming for tire size change.
    EFILive can't program the ABS module, ECM/TCM tune will not make any difference to ABS module.
    Dec 2005
    yeah seems like the deal. so if it had same size on the front it might work I am guessing its the big differance from front to back thats the problem
    Yes, it is the front-rear difference.
    Dec 2005
    pulled fuses didnt work at all so put one back and bingo
  1. Change a tire ...
    By Garry in forum Lounge
    Last Post: September 21st, 2008, 06:07 PM
  2. Tire change for track question
    By SSThunder in forum General (Petrol, Gas, Ethanol)
    Last Post: July 24th, 2007, 02:14 AM
  3. LBZ tire size change
    By BigTex in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: January 12th, 2007, 03:14 AM
  4. front tire change on a C5?
    By Highlander in forum General (Petrol, Gas, Ethanol)
    Last Post: November 1st, 2005, 02:15 PM
  5. Tire size change calulation
    By Z16DNA in forum General (Petrol, Gas, Ethanol)
    Last Post: January 19th, 2005, 08:52 AM
