see this thread for info http://forum.efilive.com/showthread....njector-tables....
I have Bosch 0280155968 injectors and after a quick run out my standards are not up for the job. there cycling at 120%
From my reading many just change the IFR. But surely thats only the start?? from what I see I need to change the following tables.
{B4006} Small Pulse Threshold
{B4001} Injector Flow Rates
{B4003} Minimum Injector Pulse Width
{B4004} Default Minimum Pulse Width
{B4005} Small Pulse Adjust
So the question is to WHAT!!!!
The IFR seems easy. Take your fuel rail preasure and the rated preasure of new injectors put it in to the XLS and cut and paste.... Simple.
The other confuse me.... I found the following infor that might help.
http://www.boschdealer.com/specsheets/0280155968cs.jpg
Any guidence is grateful. Ill start puting up the details as I get it and hopefully I can fit these shortly.
