Results 1 to 9 of 9
Thread: Newbie with LC1 and V2, install questions and help please
    Jun 2009
    Default Newbie with LC1 and V2, install questions and help please
    I have the controller wired in to ground and 12v, and am using a TAQquickness serial cable.
    When I first connected it and turned it on it did heater calibration and everything then went to a screen that says Free Air and a percentage.
    It keeps jumping from 20.8-20.9%. If I hit "OK" it says W02 Not Found.
    Am I doing it wrong?
    71 Chevelle, LS1/4l60e, EPS 230/238 113+2, hand ported 799s, ported Fast 90/90, Doug's headers, 3.42 12 bolt
    Oct 2006
    V2 "setup" select LC-1 as controller type .
    Good read ; http://forum.efilive.com/showthread....ting-LC1-to-V2 scroll down to bottom of page related post (similar threads) are listed there .
    20.8 to 20.9 is free air reading , normal .
    2006 Trailblazer
    Jun 2009
    Thanks, I turned the car on shortly after that post and discovered I was just dumb.
    Glad you got it working
    Jun 2009
    The instruction just kind of cut off after the air calibration. No hints as how long or short it would take...when it started it looked like the percentage was counting down so I was thinking it was freezing at that percentage.
    The first setup instructions seemed otherwise specific so I was afraid of doing it wrong. Just another case of me making a mountain out of a mole hill...the whole mystic of tuning has me over thinking some things and being overly cautious it seems. Time to do some heavy reading on how to start this tuning process. I'm excited, especially knowing the car is rich enough the tune should help wake up the new head/cam combo even more.
    Setup run down:
    1971 Chevelle SS clone
    1999 LS1
    hand ported/polished 799 heads milled .010"
    EPS 230/238 113+2 cam (.600/.615 lift)
    Ported Fast 90mm intake/ 90mm tb
    GM 41# injectors from supercharged Buicks
    1 3/4" longtubes, 3" duals
    4l60e
    12 bolt 3.42 gears
    Hey Thunder,
    Have a read of this (post #1 is the tutorial): A-New-Twist-on-CALC.-VE-Table..Computing-the-Entire-VE-Table.
    Jun 2009
    Thanks! I will read that one in down time at work today.
    I also have the EFI Master Tuner book, from what I've read and thumbed through of it, it looks like a great book.
    Jun 2009
    joecar: in this thread (http://ls1tech.com/forums/pcm-diagno...ng-signal.html) you mention the PID for logging a/f as WO2BEN or EXT.WO2BEN
    I only messed with EFI live for a moment but even after copying the file into the folder as directed I could not find PIDs by either of those names. Will they not show up in the available list until I do something else? I had a couple which clearly referred to a wideband o2 but they weren't named anything like those you mentioned and I haven't tried using them yet.
    Are you running WinXP or Win7 (Win7 has a slightly different folder name).
    You copied the file calc_pids.txt to the User Configuration folder...?
    After you copied the file, did you exit/restart the scantool...?
    On the PIDs tab, click on the column heading "Caption" (this sorts the pid list alphabetically on this column), then scroll down while viewing this column until you see the pid WO2BEN.
    The other wideband BEN pid(s) use GM.AFR which we're trying to avoid.
  1. LC1 connection and other newb questions
    By DaveL in forum External A/D inputs
    Last Post: August 9th, 2010, 02:08 PM
  2. Newbie Questions
    By TBMSport in forum Gen IV V8 Specific
    Last Post: May 5th, 2009, 07:12 PM
  3. LC1 install
    By jfpilla in forum General
    Last Post: September 28th, 2006, 08:14 AM
  4. newbie questions
    By RUTAN TA in forum General (Petrol, Gas, Ethanol)
    Last Post: June 12th, 2006, 03:21 PM
  5. Newbie questions.
    By 12sec.5.3 in forum General (Petrol, Gas, Ethanol)
    Last Post: March 27th, 2006, 11:02 AM
