Results 1 to 10 of 16
Thread: Gear Indication and Manual mode questions
    Apr 2010
    Default Gear Indication and Manual mode questions
    Howdy again. I have two questions that revolve around using the AMS-1000 boost controller.
    The AMS-1000 uses a 0-5 volt signal to identify what gear the transmission is in. Are there any such provisions on the factory 4l80e which I could use or make a gear indicator box from? I was hoping to leave the transmission in drive while at the track. I was thinking of using signals from the shift solenoids or something to accomplish this.
    If that is not possible I can use the dakota digital box if the transmission was manually shifted. I was thinking of using switches on the right pins to trigger "manual mode." Is that safe to use at the track? Will lock up still function..etc etc.. I would think this is the easiest way to accomplish my goals.
    Thanks,
    Steve
    Dec 2008
    One problem is they solenoids are operated by a ground signal, not a +12V.
    Apr 2010
    Good info, that is what I have found through the research I have been trying to do. Its another bump in the road but still could be used through some sort of homemade electronic box do-dad. I hope...
    How does the AMS-1000 interpret the 0-5V signal...?
    Apr 2010
    I believe (since I did not buy yet) It has an input wire for the 0-5v signal. You then put the car in each gear and press some buttons on the screen to calibrate the unit. When it sees whatever constant voltage was programed into it, it will assume you are in that gear.
    Ie 1.2volts =1st 1.9v=2nd 2.1v=3rd and so on I think it can detect a 0.1 change in voltage and be calibrated to see up to 6 gears.
    The 4L80E and 4L60E have two shift solenoids, this gives a total of four combinations (representing four gears);
    each solenoid signal is either 0V (on) or floating/12V (off);
    if they are floating, then each signal needs a pull up resistor (pulls the voltage up to 12V when the signal is off);
    then you would need a 2-bit digital-to-analog-converter made from a resistor ladder and possibly an op amp...
    for example:
    http://zone.ni.com/devzone/cda/tut/p/id/13237
    http://www.allaboutcircuits.com/vol_4/chpt_13/3.html
    http://www.baron58.com/DAC.htm
    The op amp will allow you to scale the output voltage range independently of the input voltages.
    How versed are you in electronics...?
    Apr 2010
    I am not versed well....haha well here goes?
    I have 3 5v op amps leftover from a 5v buffer project for a non lsx vehicle. Their data sheet can be seen here: http://www.ti.com/lit/ds/symlink/opa2340.pdf Would they work even though the solenoid operates on 12v? The are model OPA340PA
    Obviously I will have to do math to figure out the resistors... But, here is my first attempt after sifting through google and your links. Do I need diodes anywhere? How wrong does this look?
    More like this:
    The two vertical buffers can be CMOS inverters/buffers powered by 12V... or maybe they can be left out.
    The key points are:
    - the op amp mustuse negative feedback loop;
    - the resistances at the summing point must be R and 2R;
    - the ECU grounds the signals to turn on the solenoids, and floats them to turn off;
    - the pull up resistors pull the signals up to 12V when the ECM turns them off;
  1. Manual gear hold for A4
    By vortecyota in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: August 6th, 2010, 01:33 PM
  2. manual gear selection overide 4l80e
    By 2500ak in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: January 6th, 2010, 04:48 PM
  3. Driving A6 with gear change without tune questions?
    By beefcake in forum Gen IV V8 Specific
    Last Post: April 12th, 2009, 11:28 PM
  4. 4L60E Manual Mode Downshifting 3-2 & 2-1
    By TRANNYMAN in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: April 3rd, 2008, 08:11 AM
  5. Can Valet mode be used to turn SD mode off and on?
    By ForcedC5 in forum General (Petrol, Gas, Ethanol)
    Last Post: May 17th, 2005, 11:53 AM
